Thread Number: 26113
Maytag a2007 washer timer issues |
Post# 400912 , Reply# 1   12/20/2009 at 17:32 (5,239 days old) by vancouver2009 ()   |   | |
It actually is a Maytag a207 model (Liz) |
Post# 400948 , Reply# 2   12/20/2009 at 19:58 (5,239 days old) by qsd-dan (West)   |   | |
Sounds like a bad timer motor. It could be the escapement, but they usually hold up pretty well. Depending on your skills using a multimeter, we may be able to narrow down the problem. If not, I can give you a part# for a new timer. They usually pop up quite often on ebay for reasonable prices. I checked on line and it shows your timer as a 204454, if you have the "Permanent Press" cycle. However, online info has been wrong far too many times to trust it, so I'll peek at my microfiche slides to confirm. If you pop the console cover off (2 screws and it lefts off), there should be a part # on the timer body that will start with a "2" |
Post# 401133 , Reply# 3   12/21/2009 at 17:47 (5,238 days old) by goatfarmer (South Bend, home of Champions)   |   | |
