Thread Number: 26880
THE END OF WHIRLPOOLS POWER CLEAN DISHWASHERS |
Post# 413144   2/6/2010 at 15:22 (5,185 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
WP has just stopped making the 1/3 HP motor dishwashers I believe these to be the best performing DWs built today. IF you want a DW that still cleans where you don't have rinse your dishes with a cycle time of aprox 45minutes. grab one fast. You can find them @ lowes under mod DU943 or other places under DU930 there is also a MT model MDB4929AWS called JET-CLEAN witch does not have the indoor silverware and still has the tower in the middle of the lower rack. There is also a model avabible under the KENMORE brand. THese DWs are only arouse 300 hundred dollars I recently found them @ Lowes for 198.00 after thanks giving.These are use-sally available in WH BLACK BISCH and SS.
