Thread Number: 30442
Roper DD Question |
Post# 460857   9/2/2010 at 15:12 (4,977 days old) by macboy91si (Frankfort, KY)   |   | |
I've dealt with this once before but did not know what it was, what makes a DD WP washer agitate, neutral drain and not spin? The motor and pump run in spin, and they stop when you release the safety switch, but the basket won't actually spin? Is this a spin clutch issue and is it worth repairing. It's a very cheap 2005 Roper set that I may acquire.
Thanks! -Tim |
Post# 468081 , Reply# 1   10/8/2010 at 21:29 (4,940 days old) by yogitunes (New Jersey)   |   | |
quick question Tim.....does it agitate but not spin?.....or will it not agitate or spin?
see the motor shaft is direct with the pump, no union.... for the other side of the motor is a union or coupling they call it, there are 2 pieces with 3 fingers, one goes on the motor and the other on the tranny, and theres a big rubber bushing that connects the 2, for whatever reason these fingers break and the machine will not agitate or spin, motor will run and pump will function, but thats it.....this would be equal to a belt on a belt drive unit this little coupler cost under 10 bucks......about 7 dollars more for the heavy duty one, a 15 minute fix |
Post# 468124 , Reply# 2   10/9/2010 at 08:00 (4,940 days old) by coldspot66 (Plymouth, Mass)   |   | |
Most likely a transmission problem if it agitates but does not spin. |
Post# 468779 , Reply# 3   10/12/2010 at 12:34 (4,937 days old) by JaredH ()   |   | |
Bad neutral pak? |
Post# 468789 , Reply# 4   10/12/2010 at 13:43 (4,937 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
These little guys are extremely easy to replace. They often fail in such a way that they will agitate, but not spin.
A DD will nearly always drain because the pump is driven off the motor directly. Check if the pump is leaking, however. If it is, you must replace it and file the rust off the motor's shaft. That pump must slide on that shaft like butter. If you pound the pump, it will leak. Dave |
Post# 469269 , Reply# 5   10/14/2010 at 07:53 (4,935 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
A broken drive cupeling is NOT the problem if the washer agitates and does not spin this would be impossible. The first thing to check if the washer basket does not spin is to take the cabinet off and run the machine in the spin cycle. If the silver clutch drum is spinning the transmission is ok, You then have a broken plastic brake cam or some thing caught between the tubs or a stripped basket drive block etc. If the clutch drum is not turning you have a transmission problem.
Post# 469282 , Reply# 6   10/14/2010 at 12:43 (4,935 days old) by yogitunes (New Jersey)   |   | |
Post# 471698 , Reply# 7   10/27/2010 at 10:16 (4,922 days old) by macboy91si (Frankfort, KY)   |   | |
The machine spins most of the time now, but sometimes you have to help it or power it on and of a few times until it makes a clunking sound. I'm not very familiar with the DD's, I can replace the pumps, motor and couplers but haven't had to venture much past. The machine agitates fine and drains fine, but sometimes when it comes time for spin, it's like the drain just keeps going. When it will go into spin, it makes a light clunking sound that isn't present when the machine won't spin. Spinning the basket and/or powering the machine on and off a couple of times will make it work usually. When it finally goes, you hear the clunk sound. I was thinking there might be something with the clutch, but I don't know for sure how the DD machine goes from neutral to spin, that would be where to look possibly.
-Tim |
Post# 471811 , Reply# 8   10/27/2010 at 20:18 (4,921 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 471963 , Reply# 9   10/28/2010 at 13:27 (4,921 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 472042 , Reply# 11   10/28/2010 at 19:25 (4,920 days old) by cphifer5115 (Jackson, TN)   |   | |
the only thing i can assume is that it has to do with pulling the agitator shaft out of gear. when the motor first reverses direction for drain it also has to pull the agitator shaft into netural. when the motor stops then starts up again in the same direction it just goes str8 to spin. if you ever stop you washer in the middle of the drain cycle then start it back up again it will start to spin even though it's only suppose to drain.
