Thread Number: 31052
Speed Quen / Huebsch water level |
Post# 468602 , Reply# 1   10/11/2010 at 19:20 (4,917 days old) by JeffG ()   |   | |
How close is the water level to the top row of tub holes? |
Post# 468718 , Reply# 2   10/12/2010 at 06:24 (4,916 days old) by mrb627 (Buford, GA)   |   | |
Post# 468760 , Reply# 3   10/12/2010 at 11:04 (4,916 days old) by DanManTN (Tennessee)   |   | |
That happened to me. I think I ended up with 8 turns. The screw threads are what determine how many turns--and apparently they vary by model, mfg date, etc. All it is doing is pushing against the button on the sensor (to see this work, turn the knob to 'reset' on the water level knob and back a few times. It's truly trial and error...took 3 tries to get mine right.
Post# 468849 , Reply# 5   10/12/2010 at 18:46 (4,916 days old) by danmantn (Tennessee)   |   | |
As I mentioned before, depends on the thread pattern of the screw. Your thread pattern may be different...make a small adjustment, fill the tub and see if that is what you want. Repeat until desired water level. Just don't fill to the top of the stainless...need some 'sloshing' room when washing bulky things like throw rugs. Which should always be washed on gentle or the wash basket will rock back and forth a lot! Mine is AWN542.
Post# 468918 , Reply# 7   10/12/2010 at 21:59 (4,916 days old) by DanManTN (Tennessee)   |   | |
Post# 468994 , Reply# 8   10/13/2010 at 05:25 (4,915 days old) by mrb627 (Buford, GA)   |   | |
