Thread Number: 32355
Whats your dishwahser?
Cool Washer Stuff on Amazon:
scroll >>> for more items
Post# 487915   1/10/2011 at 12:38 (4,716 days old) by jlbrazil (brazil)
Hey guys , I'm a bit new here , and I may lost alot of interesting threads of dishwashers :(
I just love them and seeing pics of how other people load them.
So here I propose you to tell us the model of your dishwasher , the year you bought it and then you can upload some pics of it.
It would also be nice if you could upload some pics of a bob load or just a Daily load.
I hope you like my idea.
Cheers :)
Post# 487918 , Reply# 1   1/10/2011 at 12:42 (4,716 days old) by jlbrazil (brazil)
Let's start
So guys , I'm gonna start with my DW :)
It is a Whirlpool Sixth Sense , 12 place settings and made in Germany.
It is rated :
A energy
A wash
A dry
On the test cycle ( Eco Wash ) it uses 12 liters and 1,2 kWh.
The machine is really quiet , rated at 44dB.
You can also see some pics :)
Post# 487922 , Reply# 2   1/10/2011 at 12:48 (4,716 days old) by jlbrazil (brazil)
Post# 487924 , Reply# 3   1/10/2011 at 12:52 (4,716 days old) by jlbrazil (brazil)
This is the options.
The time delay goes up to 24 hours.
The Multi Zone I can select the basket I want to use.
Sani rinse is a 75*C rinse. If you keep opening the door during the final rinse , the machine certainly won't be able to keep the temperature for the full 3 or 4 minutes.
Then , if it couldn't reach , at the end of the cycle the Sani Rinse light will flash.
Post# 487925 , Reply# 4   1/10/2011 at 12:52 (4,716 days old) by jlbrazil (brazil)
Here the label :)
Post# 487926 , Reply# 5   1/10/2011 at 12:56 (4,716 days old) by jlbrazil (brazil)
Today I just threw some dishes on the Eco Wash ( Cold pre rinse , 50°C or 122°F wash , a cold rinse and a 65°C or 149°F rinse , 40 minutes dry [ on the test cycle the dry phase is longer for a A dry on the label] )
Post# 487927 , Reply# 6   1/10/2011 at 13:02 (4,716 days old) by jlbrazil (brazil)
More of the load.
Post# 487928 , Reply# 7   1/10/2011 at 13:03 (4,716 days old) by jlbrazil (brazil)
Aww , forgot to say , I bought it in June , 2010
Post# 487931 , Reply# 8   1/10/2011 at 13:35 (4,716 days old) by servisslimline (England, Brighton & Hove)
my dishwasher
servisslimline's profile picture
its a Tricity Bendix DH090 bought inn about 2002.
it was a good dishwasher for the first year then all of a sudden faults sarted developing, from the door lock to the main control board and from that i think you can guess whats happened to it now.... yes....ITS DEAD after just 8 years in operation, it died late 2010 around october time i think and to be honest im glad its finally given up the ghost.
pictures to follow soon!
phil
Post# 488029 , Reply# 9   1/10/2011 at 19:01 (4,716 days old) by favorit ()
2nd hand Bosch here :)
Hi JLBrazil,
I was about to start a new thread with my new "baby" when I read your one :-)
So my DW is a Bosch SGS 8572 made in 1997
Post# 488034 , Reply# 10   1/10/2011 at 19:13 (4,716 days old) by favorit ()
both racks are identical
BSH used to call this serie of DW Two-in-One : the two buttons on the right of the handle are DUE CESTELLI = TWO RACKS and CESTELLO SUPERIORE = UPPER RACK. Small loads are washed in the upper rack only, while full loads can be loaded as one wants, no need to split into pot--> lower rack and glassware ---> upper rack. This configuration works great for small households, but I guess it's not so useful for those that need to wash many dishes. I' thinking of Zanussi-Electrolux DW that can wash two racks fully loaded with dishes only
Post# 488036 , Reply# 11   1/10/2011 at 19:16 (4,716 days old) by favorit ()
lower spray arm and filter
not very different from current BSH
Post# 488037 , Reply# 12   1/10/2011 at 19:19 (4,716 days old) by favorit ()
loaded
but nut Bob-loaded : those stemmed glasses don't allow it ! :)
Post# 488038 , Reply# 13   1/10/2011 at 19:21 (4,716 days old) by favorit ()
lower rack
Post# 488039 , Reply# 14   1/10/2011 at 19:23 (4,716 days old) by favorit ()
upper rack
Post# 488042 , Reply# 15   1/10/2011 at 19:26 (4,716 days old) by favorit ()
Logixx
Have to say thanks to Alex/Logixx.
His vids on YouTube of his Siemens DW are so impressive that convinced me about BSH DW quality
Post# 488044 , Reply# 16   1/10/2011 at 19:36 (4,715 days old) by favorit ()
Bras....unecht !!
CLICK HERE TO GO TO favorit's LINK
Post# 488054 , Reply# 17   1/10/2011 at 20:07 (4,715 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
my dishwasher sears kenmore elite
hello everyone here is a pic of my kenmore dishwasher elite
Post# 488059 , Reply# 18   1/10/2011 at 20:11 (4,715 days old) by kevin313 (Detroit, Michigan)
My Asko 1375
kevin313's profile picture
Here's the front - not too fancy, but this dishwasher is whisper quiet, has a stainless steel interior and upper and lower jets. Gets dishes really clean.
I've had it since new - 10 years, and never had a problem with it until this week. It seems the inlet valve went bad, so I'm in the process of getting it fixed.
I thought, maybe after 10 years I should get a new one, but I think this still has some life left in it and I'm not ready to learn a new machine!
Post# 488061 , Reply# 19   1/10/2011 at 20:12 (4,715 days old) by kevin313 (Detroit, Michigan)
Asko 1375 front controls
couldn't be more simple - do they even make dishwashers with knobs anymore??
Post# 488135 , Reply# 20   1/11/2011 at 04:58 (4,715 days old) by jlbrazil (brazil)
favorit...
Thanks for the replys :)
I liked your Bosch , very different upper rack.
Ah , really similar machine :D
But I've already seen an identical one :)
Post# 488179 , Reply# 21   1/11/2011 at 11:57 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
Miele G2830 purchased in June 2006. This is a picture of the control panel...I guess not much to see. It consists of a display screen and touch areas that you use to scroll the display up and down. You scroll to select the program cycle you want to use. You can re-order the listing so that the programs you use the most appear near the top.
This post was last edited 01/11/2011 at 12:17
Post# 488181 , Reply# 22   1/11/2011 at 11:58 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
After you select the cycle you can add additional options if you like
Post# 488184 , Reply# 23   1/11/2011 at 12:02 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
Lower wash arm and filters. Sorry there is some dirt here but the picture was taken after some dishes were loaded.
Post# 488185 , Reply# 24   1/11/2011 at 12:04 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
This is an everday load.
Lower rack
Post# 488186 , Reply# 25   1/11/2011 at 12:05 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
Middle rack
Post# 488187 , Reply# 26   1/11/2011 at 12:06 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
Upper rack
Post# 488188 , Reply# 27   1/11/2011 at 12:13 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
lower rack clean
Post# 488190 , Reply# 28   1/11/2011 at 12:14 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
middle rack clean
Post# 488191 , Reply# 29   1/11/2011 at 12:15 (4,715 days old) by jerrod6 (Southeastern Pennsylvania)
upper rack clean
Post# 488193 , Reply# 30   1/11/2011 at 12:19 (4,715 days old) by jlbrazil (brazil)
Jerrod
Wow!
What a nice DW.
I really love Miele.It's a shame there isn't Miele in Brazil :(
Post# 488216 , Reply# 31   1/11/2011 at 14:10 (4,715 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
foraloysius's profile picture
Here's a video of my dishwasher. It's an AEG Öko Lavamat 6060 from 1995.
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385">
Post# 488252 , Reply# 32   1/11/2011 at 16:51 (4,715 days old) by favorit ()
Louis
so now shall I upgrade my nick into Lavamat ? ;-)) *LOL*
This is a freudian typo *LOL*.
Don't allow your DW to read AW.org, otherwise she may be jealous of the Lavamat and of the Novotronic ... and she even could go on strike *LOL*
Post# 488337 , Reply# 33   1/11/2011 at 21:33 (4,714 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
Oh goodness, I was tired when I posted. Ofcourse it's an AEG Öko Favorit 6060. Duh! lol
Post# 489498 , Reply# 34   1/17/2011 at 07:07 (4,709 days old) by logixx (Germany)
logixx's profile picture
Thanks, favorit! :)
Yes, I really like our B/S/H dishwasher. A realitve of mine had a Neff 2-in-1 like the one above. Really clever design - the racks are very similar to the one in B/S/H's first counter-top dishwasher.
This is a more recent load in our 2006 Siemens:
Post# 489499 , Reply# 35   1/17/2011 at 07:08 (4,709 days old) by logixx (Germany)
upper rack
Post# 489500 , Reply# 36   1/17/2011 at 07:09 (4,709 days old) by logixx (Germany)
more stuff
Post# 489503 , Reply# 37   1/17/2011 at 07:13 (4,709 days old) by logixx (Germany)
Post# 489519 , Reply# 38   1/17/2011 at 08:00 (4,709 days old) by jlbrazil (brazil)
Logixx
Hey Alex , thanks for uploading those pics of such a nice load :)
I really love your siemens DW :D
It seems to be amazing!
Post# 489791 , Reply# 39   1/18/2011 at 04:29 (4,708 days old) by Maytagbear (N.E. Ohio)
Mine?
is a GE Nautilus portable, and it's the quietest portable dishwasher I have ever had, and one of the better cleaning dishwashers I have ever had.  Very rarely is there anything to rewash.
Best cleaning dishwasher was my first, a reverse-rack Maytag portable, WC400, from 1973.
Lawrence/Maytagbear
