Thread Number: 39676
A Great Easter Weekend |
Post# 587692   4/7/2012 at 10:19 (4,374 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 587694 , Reply# 1   4/7/2012 at 10:28 (4,374 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 587699 , Reply# 2   4/7/2012 at 11:22 (4,373 days old) by westingman123 ()   |   | |
That's fine, son, just fine. You gotta love a Lady. |
Post# 587701 , Reply# 3   4/7/2012 at 11:37 (4,373 days old) by kakidd (Texas)   |   | |
I always loved how Sears lit up their Ladies for dishes equally as well as they lit up their Ladies for laundry in this era! Hope you're planning a big Easter brunch tomorrow to test her out! Congratulations!
Post# 587705 , Reply# 4   4/7/2012 at 11:56 (4,373 days old) by chachp (North Little Rock, AR)   |   | |
Post# 587714 , Reply# 5   4/7/2012 at 12:49 (4,373 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 587718 , Reply# 6   4/7/2012 at 13:16 (4,373 days old) by pdub (Portland, Oregon)   |   | |
Post# 587739 , Reply# 7   4/7/2012 at 14:09 (4,373 days old) by polkanut (Wausau, WI )   |   | |
Post# 587778 , Reply# 8   4/7/2012 at 15:47 (4,373 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 587783 , Reply# 9   4/7/2012 at 15:57 (4,373 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 587787 , Reply# 10   4/7/2012 at 16:21 (4,373 days old) by xraytech (Rural southwest Pennsylvania )   |   | |
Post# 587797 , Reply# 11   4/7/2012 at 17:55 (4,373 days old) by william637 (Damp pants? Not a chance. )   |   | |
No leaks, and wow that lady can pump some water.
But, during the second fill, it seems to have shorted out (at least it keeps tripping my GFI). My guess is its the heating element (which got fired up when I did a rapid advance of the timer, just before I started it again for the second fill), or the solenoid (which seems to be defaulting to an open position). So, now to get the water out, and start yet another project..... |
Post# 587838 , Reply# 13   4/8/2012 at 00:40 (4,373 days old) by PhilR (Quebec Canada)   |   | |
Wow, that's a nice find! I didn't know there were LK top loading dishwashers. Split roto rack is ingenious but I still can't figure how you can lift it to add dishes to the lower rack it once you started to load the second rack? I suppose you need to overload one of the racks until the lower rack is full and then redistribute the dishes to balance the load between the two racks.
Edit: I thought the racks were on hinges at the center, I looked again and I can't see how one could fold without being blocked by the tub, so I guess they have to be removed from the center post? That makes more sense! It would be nice to see a video of it with a plexiglass on top while it's washing dishes! |
Post# 587880 , Reply# 15   4/8/2012 at 08:16 (4,373 days old) by PhilR (Quebec Canada)   |   | |
I know from loading my '65 D&M impeller dishwasher that loading glasses in top loading dishwashers can be a bit tricky (at least those that don't have upper racks that move away when opening the door)!
In mine, there are two center sections that fold over the outer sections, just folding one is enough to place dishes on the lower rack (so you can fill the 3/4 of the upper rack and have access the lower one) but you can't put tall glasses on one of the side because if you do you can't fold either parts of the center section so they in place... And if you put a large glass near where the center sections are hinged to the outer section, you have to be careful not to crush the glass either. It happened to me and I needed to remove everything from the dishwasher to clean the pieces of glass that got to the sump near the impeller... |
Post# 587894 , Reply# 16   4/8/2012 at 10:41 (4,372 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Mark congratulations on finding a rare cool machine, I remember these when they were still being sold. Robert hit it correctly as it would be 1966-1969 vintage the last 4 digits of the serial # may tell you the exact build date. This machine has very good water distribution so it gets everything thoroughly drenched, it also had the best food grinder of any DW made at this time, so it will eat any soft and some not soft food bits. The bad thing is no filter so if things touch or nest together food bits may remain dried in place.
One of the other good things about this DWs performance is that it is one of the few classic DWs that will clean great on 120 degree water incoming water if you use the PINK 150 button as this cycle heats the 2nd wash and final rinse to 150. And even on the normal cycle the heating element is on to boost temps. One of the worst things you can do any DW especially a classic one is to get the incoming water temps over 140 and lower is even better, newer detergents do not need extremely high temperatures.
If you have control over water temps where you live it is a good idea to experiment and see what is really necessary for good results. Always keeping in mind that not only will you save real money on operating your water heater and increase safety for anyone in your household. But the real benefit is much longer water heater life and every plumbing component in your homes hot water system including the hoses and inlet valves in any appliances you have. |
Post# 587915 , Reply# 17   4/8/2012 at 13:07 (4,372 days old) by PhilR (Quebec Canada)   |   | |
John, what could happen (to the dishwasher) if the water temp from the tank is too hot? I think the setting on my water tank thermostats is currently a bit above 140 degrees (140 is the factory setting for electric water heaters in Canada)... It probably drops a few degrees before it arrives to the dishwasher, I'll have to check that.
Post# 587918 , Reply# 18   4/8/2012 at 13:18 (4,372 days old) by william637 (Damp pants? Not a chance. )   |   | |
John
I am curious about the damage that hot water can cause to the machine. The tap water at my house is between 150 and 155. I know that can be bad on hoses and seals in valves. For that reason, all of my permanently installed items (daily driver dishwashers and washing machine) have ss braided hoses. Whether they need it or not I replace them every few years. What other damage have you found by hot water? I would think that a machine that heats to 150 wouldn't have a problem other than the hoses? Thanks for the tip - look forward to hearing back. -Mark |
Post# 587919 , Reply# 19   4/8/2012 at 13:36 (4,372 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Everything including porcelain tanks, plastic parts, plastic coated racks, rubber parts of the machine, nylon inlet valves will deteriorate faster [ including your dishes ] especially when combined with caustic detergent. It is fairly simple chemistry heat increases chemical reactions, rust, corrosion etc. To say nothing of the tank and heat exchanger in Gas water heaters, heating elements and tank in electrics and anodes that help protect the tank and plumbing. Your plumbing system including metal and plastic piping and faucets are all affected the hotter the water is.
I have had many plumbers tell me over the years that people that keep there water heaters tank temperature at or below 120 that the water heaters will last twice as long. We as service people see a big difference in the life of DWs overall and inlet valves in washing machines where the hot water temperature is very high. |
Post# 587922 , Reply# 20   4/8/2012 at 13:47 (4,372 days old) by appnut (TX)   |   | |
John, if people keep their water heaters set at those settings and vintage dishwashers reqiure water of 140 degrees or more to clean the way they were intended to perform, how does one reconcilew those differences. Semi-vintage dishwasher models often do heat the water at least during the main wash phase. And what about getting laundry clean and whites white with lower temps. At least my front loader can heat water to 155 degrees or 130 degrees also.
Post# 587928 , Reply# 21   4/8/2012 at 14:20 (4,372 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 587940 , Reply# 22   4/8/2012 at 14:43 (4,372 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
DWs that lack booster cycles for heating the main wash will not work to the best of their abilities if used on 120 degree water temps. Although newer detergents do work at cooler water temperatures and you may be able to reduce the temperature somewhat. The LKM portable DW that is the subject of this thread will actually work on cold water if the Pink button is selected.
If I were going to regularly use a vintage DW and had electric water heat in the house I would probably install a 5 or 10 gallon electric water heater near the DW. There would be various ways you could use this to heat enough water for a good DW cycle. If you have a gas water heater I would get an electric instantaneous heater to boost the hot water supply as it enters the DW. We did this at our warehouse and it works really well in boasting 115-120 degree water to over 140 as fast as the DW fills, of coerce this would also work for homes with electric water heaters. |
Post# 587974 , Reply# 23   4/8/2012 at 19:54 (4,372 days old) by william637 (Damp pants? Not a chance. )   |   | |
Ok
So I think my problem is the fill solenoid. Still playing with it, and if the faucet is turned on, water ALWAYS enters the tub, at a slow pace. Even during the fill portion, the water enters at the slow pace (won't get enough water to keep the pump from starving). Anybody replaced the fill solenoid in a machine like this? Are they universal (i.e. will a new fill solenoid work with this machine, or do I have to find the original OEM part?) Thanks! |
