Thread Number: 40096
/ Tag: Vintage Dishwashers
GE2800 Photos |
Post# 593556 , Reply# 1   5/2/2012 at 05:20 (4,374 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 593570 , Reply# 2   5/2/2012 at 06:49 (4,373 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 593574 , Reply# 3   5/2/2012 at 07:06 (4,373 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 593575 , Reply# 4   5/2/2012 at 07:08 (4,373 days old) by cyclemonitor ()   |   | |
suffice |
Post# 593576 , Reply# 5   5/2/2012 at 07:10 (4,373 days old) by cyclemonitor ()   |   | |
more |
Post# 593578 , Reply# 6   5/2/2012 at 07:11 (4,373 days old) by cyclemonitor ()   |   | |
more |
Post# 593579 , Reply# 7   5/2/2012 at 07:12 (4,373 days old) by cyclemonitor ()   |   | |
one |
Post# 593580 , Reply# 8   5/2/2012 at 07:13 (4,373 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 593618 , Reply# 9   5/2/2012 at 09:06 (4,373 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 593784 , Reply# 11   5/2/2012 at 23:17 (4,373 days old) by Ultramatic (New York City)   |   | |
Post# 593828 , Reply# 13   5/3/2012 at 06:49 (4,372 days old) by william637 (Damp pants? Not a chance. )   |   | |
I also have a 1200 in the basement. It is what came with the house when I bought it. The control panel is scratched up (why do people insist on cleaning printed/painted control panels with abrasives?), but otherwise it works. If the video isn't found I can hook mine up and make one. It's kinda fun listening to the timer automatically advance.
Post# 593830 , Reply# 14   5/3/2012 at 07:16 (4,372 days old) by chris74 ()   |   | |
... that these heavily computer-controlled machines are so outdated now... |
Post# 593833 , Reply# 15   5/3/2012 at 07:36 (4,372 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These Models with the Multi-orbit lower wash arm, Self-cleaning filter, heavy die-cast control panel, heavy molded tub and door liner with a heavy duty metal frame around it, and even additional support for the extra-deep upper rack in the form of an extra Axel and wheels that ran on the ceiling of the tank. IMEO this was the first time that GE got really serious about trying to compete with the big boys by with a built-in a DW that could compete with KA, WP, and MT in terms of performance and long term durability as they wouldn't rust out in ten years or less.
I would never have seriously considered a GE DW in my home until these machines came out. They do still have several serious short comings when you compare them to WP or KA DWs of the same time period. The lower rack just doesn't allow random loading, it is too cut up with the Silver Ware basket in the front, the wash tower in the center and the silly saucer space right behind, as a result the LR holds less than a dozen dinner plates. If you try and load the lower rack heavily with pots, pans and bowels items wouldn't get washed in the corners of the otherwise excellent top rack.
But to me the most worst part of this machine was they used the same motor and pump that they put in their cheapest builder machine. It was always interesting when looking at the beautiful brochures for these DWs that GE barely mentioned that it even had a motor let alone its HP LOL. But it used noisy inefficient 1/6 HP motor that used as much power as KAs 1/2 HP motor did and put out even more heat. The nice thing is that if you want to use one of these machines today as an everyday machine you can easily install the new PSC motor and cut the power consumption down to 1/3 and reduce the noise as well. And the grinder was [ and still is in current GE DWs ] a very fragile little affair that can be easily destroyed by hard objects, they have changed the design of this many times over the years but still have not manged to get one that cannot be broken easily. The one good thing about GEs huge noisy fan that was used to cool the most inefficient motor ever used in a home DW was that all that hot air blowing around helped dry up the water that was often leaking from the trip shaft seal of other points under the DW. |
Post# 593839 , Reply# 16   5/3/2012 at 07:58 (4,372 days old) by william637 (Damp pants? Not a chance. )   |   | |
I had always assumed that the motors between DW manufacturers were of roughly equal efficiency - i didn't know the old GE motors turned more electricity to heat than kinetic energy. That'll teach me to assume things again...
That said, it makes me feel better about the motor/pump replacement I have done on my 2800. I didn't think there was anyway that the new assembly could possibly deliver enough water volume to make the spray arms work as originally designed. Even with the new motor being much more efficient, the new impeller and pump housing is so much smaller I don't see how it is going to be able to produce the same flow rate. What is your experience with this? I also liked your comment about the leaks and the heat drying the water. I was amazed at the rust down there. Just before I did the replacement, I looked at the 1200, and rust in the same spot. I picked up another BOL GE DW from habitat for $25 and was going to use the pump and motor off it (rather than order a new assembly from partsdirect.com), but lo and behold, it leaked in the same spot too! I had wondered why people didn't have rotten floors since all GEs seem to leak in the same spot. Now I know. And finally, I like you, like the multi-oribt wash arm. That was by far one of the most clever features of the machine. Whoever came up with that should get an "a". |
Post# 593854 , Reply# 17   5/3/2012 at 08:54 (4,372 days old) by peteski50 (New York)   |   | |
Post# 593908 , Reply# 19   5/3/2012 at 12:42 (4,372 days old) by joefuss1984 (Little Rock, AR)   |   | |
Post# 593910 , Reply# 20   5/3/2012 at 12:44 (4,372 days old) by william637 (Damp pants? Not a chance. )   |   | |
Thanks for your post bwoods - I am going ot have to hook up one my GE dishwashers and try the peanut butter test. I don't doubt what you say (ok - I do a little bit, but I guess I am about to be proven wrong), but when I worked at Lowe's years ago, we had a GE dishwasher with a plastic door. I was able to watch the angle of the water shooting out of the power tower. I still don't see how it can get into a glass (or jar) around the perimeter to the machine - especially the corners.
But - I like your experiment idea and I am going to try it. |
Post# 593913 , Reply# 21   5/3/2012 at 12:50 (4,372 days old) by roto204 (Tucson, AZ)   |   | |
I used to! I chucked it after the fifth time I walked into the kitchen and found ice-cold water and a beeping dishwasher complaining about a blocked wash-arm. (It wasn't. The sensor was getting pissy--or else the electronics were--in old age.) The detergent cup sensor was also faulty, and 9 out of 10 cycles started with a "Cup Open" error that I had to bypass.
I have the KDS-20 now. Live has been much simpler ever since not being constantly scolded by a dishwasher.
I agree that the 2800 was the first real competition finesse- and performance-wise to the big leaguers, but the electronics were a detraction, not a plus, in the long-term. But then again, that was back in the eighties, when anything futuristic had electronics as a matter of course, before we realized that they actually create more problems than they address. |
Post# 593917 , Reply# 22   5/3/2012 at 13:08 (4,372 days old) by joefuss1984 (Little Rock, AR)   |   | |
william637 - I have had this exact problem with any GE appliance I have owned. The back left corner of the top rack of my newer near TOL Hotpoint had this problem. My BOL newer Americana is better about it but the top rack still seems neglected after most loads as there a sprinkling of food bits usually and I am very cautious not to block the tower openings. It needs a sprayer on the top to spray down on the top rack. |
Post# 593939 , Reply# 23   5/3/2012 at 13:51 (4,372 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
John, are you having a bad day? When I got my 1200 from you last fall, you seemed to sing more praises about this line of machines than you are today. Now they seem to be relegated to Maytag's best cousin status?
I have had what are probably several very good dishwashers, and one piece of sheet, at least in my opinion, so I admit that for many years I've been spoiled. Having a WP DU6000, a new GE Potscrubber 2200 (the lightweight electronic version of the 2800 with a lot fewer fancies), a Potscrubber 1200 which I bought new, a GE tall tub heap of stanky crap PDW7300, and now the used 1200 with the new motor/pump, all I can say is it is VERY nice to be freed from 8 years of dishwasher hate. I am right back to my old use habits, usage patterns which didn't want to die but had to in order to make the '7300 work anywhere near sufficiently. I generally do not challenge a dishwasher but in one way -- in that I load it throughout the week, do not use rinse/hold and expect it to remove dried on foods that have been sitting for days. The only dishwasher of mine that had an isue with that was the '7300. Now that it has moved on to trouble someone else incessantly, I don't worry much about dried on stuff once again. That said, I don't totally agree with a few comments made regarding the 1200/2800's lower rack (this rack was used in most other GE dishwashers of the period too, including my Mom's 1987 Potsrubber 900). I will say that my last 1200 was of a newer generation than the one I have now (with the Ivory racks) and it held one more plate on the right side in both front and rear quadrants), but even with my current 1200, I can get at least one dozen dinner plates in the bottom rack if need-be, and still litter the edges of the rack with bowls (I don't wash bowels in the dishwasher typically) and cookware and not have a washability issue with items in the corners of the top rack. I will admit that this rack in general lacks capacity and is primitive as compared some newer racks, but I will not judge a 30 year old appliance using current standards. Oddly, and perhaps I am an easy GE customer for these machines, I LOVE what you all call the saucer rack. BUT, I defy you to call it that in all seriousness because I never have saucers to load in it; instead I usually fill it with a half dozen cereal bowls. This is a perfect place for them - they are out of the way, they don't flop around on themselves there, and they are placed far enough apart for easy loading and water flow. On the old style motor - some may think they are junk, but who really cares about it's horsepower rating if it gets the job done? My mother's 900 was in service for 17.5 years. It ran about 8 times per week for its first four years, then about 3-5 times weekly after that for almost 14 years. The motor is not what killed the machine, in fact it was useable when it was replaced (the door spring broke). To me that's not a bad motor design, period. I'll not argue that the replacement motor is better, but the old one worked fine and did what it was supposed to do and could obviously carry the appliance through its service life. If given a choice of the Potscrubber 2800 or the 1200, I would go with the 1200 time and time again due to the lack of electronics, but either way I think these are GREAT machines and I am glad to be able to enjoy using my dishwasher again. Here's a pic from installation day last September. Gordon |
Post# 593960 , Reply# 24   5/3/2012 at 15:48 (4,372 days old) by roto204 (Tucson, AZ)   |   | |
Ours in SF underfilled, but performed well if you chucked in extra water. It never groused at me or stopped due to a sensed condition, so I liked it that much better.
" I still don't see how it can get into a glass (or jar) around the perimeter to the machine" The wash tower on these is unlike any other before. It is not the crappy little dual-slot number that was on lesser machines before and since. It sends a T-shaped stream out to the edges, which apparently has enough "oomph" to swirl up the sides and touch the top of most tumblers placed at the corners. Ours never had a problem cleaning the furthest reaches.
Oh, and Gordon, no teacup saucers? Even I had saucers to go up there, and my card hardly ever gets stamped anymore. ;-) |
Post# 593966 , Reply# 26   5/3/2012 at 16:07 (4,372 days old) by bwoods ()   |   | |
Post# 594027 , Reply# 28   5/3/2012 at 19:19 (4,372 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Gordon I am not having a bad day, LOL, I thought that was a fairly positive post. I do believe that I stress a DW much more than you do, while I haven't been in your home I did watch you load Kevin's DWs. I pack my DWs to the gills and always stuff all pots and pans, bowls are at least triple stacked on top of each other and always get good results from the WP PC and the KDSS-20, only real problem with the KA is that you often have to clean the filter once or more mid-cycle as it will completely clog sometimes. I do put dishes in that dirty. I do find as stated in my post that I find the above mentioned GE DWs very good overall, but when I pack the lower rack items do not get cleaned in the corners. WATER WILL NOT CHANGE DIRECTION IN MIDSTREAM. And If GE actually got this to work one has to wonder why not only GE but every other DW made worldwide now has a full upper wash-arm. I really dough that GE found a way to do this. Barry I would love to see pictures of those tall glasses with peanut butter getting clean in the corners of the top rack. Better yet I have an original GSD-1200 that even has the original shaded pole motor at the museum that is fully restored condition, I hope you get a chance to visit and we can do some competitive tests.
Mark both the original shaded pole motor pumps and the newer PSC pumps have exactly the same main wash impeller, in fact both style pumps use the SAME pump rebuild kit, and as far as I can tell the PSC motor [ which is more powerful ] actually runs faster and unlike the shaded pole motor its speed doesn't waver as it works. That was one of the things I always hated about the shaded pole motors as they sounded like they were straining as they ran because the sound and speed constantly varied. |
Post# 594039 , Reply# 30   5/3/2012 at 20:50 (4,372 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
John - you said that you think you stress a dishwasher more than I do. I am apt to agree with you to a point, but not because of the way you saw me loading Kevin's dishwashers. I have no experience using a top load dishwasher, and prior to your arrival we had quite a bit of trouble with stuck on yibbles (oatmeal) in Kevin's recent KA tall tub. Thus I was not using either in a way that I do at home.
The real answer there is I don't have the sheer volume of items to put in my dishwasher loads before something runs out. Yesterday I was out of cereal/soup spoons and bowls, for example, so I ran the machine. It was decently loaded, but could have been "full-er". During the holidays, when I have more people here dirtying more of everything, I stack more stuff in. Ironically, since I ran the 1200 late last night, it was untouched today so I took a few pictures when I got home, just for this thread. This is a light load. Nothing I have ever gets pre-rinsed unless there are spoon or fork-sized CHUNCKS and wads of food that are better brushed off into the garbage. Many of my bowls have had microwaved torched sauces on them, etc. This was where my problem with the '7300 began, which worsened with my large skillet, etc. I will now defer to my phone to upload the two pics so I don't have to transfer them from phone to computer. G |
Post# 594040 , Reply# 31   5/3/2012 at 20:51 (4,372 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Post# 594041 , Reply# 32   5/3/2012 at 20:53 (4,372 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
Post# 594042 , Reply# 33   5/3/2012 at 20:55 (4,372 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Post# 594045 , Reply# 34   5/3/2012 at 21:21 (4,372 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Post# 594046 , Reply# 35   5/3/2012 at 21:22 (4,372 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Post# 594108 , Reply# 36   5/4/2012 at 07:34 (4,371 days old) by william637 (Damp pants? Not a chance. )   |   | |
This is an excellent thread. I have decided that since I have a 1200 with the original motor and pump and the 2800 with the new motor and pump, I can run both side by side and see what happens. Who cares if the 1200 leaks right now? It's down in my basement where I can make as big of a mess as I want. I'll let y'all know how it turns out, but it will be a few weeks. I am leaving for Milwaukee right after work for a great weekend (going for the 97th birthday of a college friends grandmother - she still lives alone and is an amazing woman). Next weekend is race weekend in Charlotte. I plan on being very drunk on Saturday and very hungover on Sunday. If anybody from this group is in Charlotte for the all-star race, hit me up. We will be tailgating all day.
Ok, back to dishwashers. I mentioned before that the 2800 was a lucky find for me. The habitat store has been a trove of treasures. I found my 1-18 there. On the day that I found the 2800, I spied the Hotpoint version of the 2200 at 20 paces. I quickly went and oohed and aaahed over it and knew I was going to by it. But I kept thinking to myself "wow, this is cool and all, but I really wish I could find a 2800". And lo and behold (I don't know how I missed it), I looked to the right and a 2800 was sitting right there. Truly a gift from God. |
Post# 594111 , Reply# 37   5/4/2012 at 07:59 (4,371 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 594127 , Reply# 39   5/4/2012 at 09:52 (4,371 days old) by franksdad (Greenville, South Carolina)   |   | |
I have a vintage orange Fiesta Wear plate. It is probably 60 or 70+ years old. I was given the orange, green, blue, and yellow plates by a very dear friend who is 73 y/o. These were the only pieces left of her mother's set that my friend, who was trying to show her mom she was a big girl and could clean off the dining room table all by herself, accidentally broke when she was a little girl. I never knew the orange was radioactive! I l o v e Fiestawear and have quite a bit of it; though not vintage. The Dish Barn in Flat Rock, NC has sold Fieata Wear by the piece for decades. It used to be very inexpensive. Operative phrase here is "used to be." You can still by a four piece place setting for $28.00 at the Dish Barn but they make up their profit margin on accessories - of which they have an unbelievable stock. |
Post# 594144 , Reply# 40   5/4/2012 at 11:19 (4,371 days old) by william637 (Damp pants? Not a chance. )   |   | |
You know, that is a good question. I honestly don't remember. The dishwasher came with the house, but I put my favorite Frigidaire in within a month or two of moving in. The 1200 hasn't been cranked up in about 5 years, except when I was working on the 2800 this past winter I put the 1200 up on the table to see what parts I was going to need to order for it as well.
I guess when I get it started I will have to document that as well.
Looks like I need to get by but in gear! |
Post# 594146 , Reply# 42   5/4/2012 at 11:43 (4,371 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Barry -
My Fiestaware is all quite new. The oldest piece in my pictures is the seafoam green bowl, which we found at a consignment shop. Most of the rest was given to me as birthday and Christmas gifts over the last couple years. My Mom and Sister have it too - mine is probably the smallest collect, my Mother's the largest. She has 12-14 dinner plates among lots of other stuff. A few of hers are older also (I got some Pink/Rose color on ebay) but none of ours dates back to the time they made food glow in the dark. My 1200 is a G model (my last one was an L). It does two rinses in Energy Saver and Light Wash, but three on the Normal and Potscrubber. Last year when I posted getting this machine, I posted also that I found the owner's manual for my L model. It shows doing two rinses in all cycles I believe. I can dig out the pics of that if you'd like to see them again, or they're in the 2011 archives. Gordon |
Post# 594176 , Reply# 43   5/4/2012 at 13:23 (4,371 days old) by bwoods ()   |   | |
Nice collection, Gordon! I'll check out the archives for your previous posting on the 1200. |
Post# 594184 , Reply# 44   5/4/2012 at 13:57 (4,371 days old) by rinso (Meridian Idaho)   |   | |
Owned one of these in the mid-1980's. It performed flawlessly, though IIRC, it wasn't all that quiet. Too bad GE can't bring this kind of quality back to their current line of dishwashers. |
Post# 594194 , Reply# 45   5/4/2012 at 14:23 (4,371 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 594195 , Reply# 46   5/4/2012 at 14:24 (4,371 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 594198 , Reply# 47   5/4/2012 at 14:29 (4,371 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 594232 , Reply# 49   5/4/2012 at 18:02 (4,371 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Post# 594291 , Reply# 50   5/4/2012 at 22:50 (4,371 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 594324 , Reply# 52   5/5/2012 at 00:32 (4,371 days old) by washer111 ()   |   | |
By the way guys, I have the user guides on my PC (from the GE website) of the 1200S, M/V and L along with the 2800's user guide. So you can just tell me to refer to the appropriate guide, if necessary :D |
Post# 594451 , Reply# 53   5/5/2012 at 18:24 (4,370 days old) by washer111 ()   |   | |
Bumping the thread: See reply #51 |
Post# 595025 , Reply# 54   5/8/2012 at 07:33 (4,367 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Barry thanks for all the provided information and your thoughts on the two types of motors used in GE DWs, but I wanted to add a few thoughts and corrections.
The original style motor used by was a shaded pole motor and while technically an induction motor SP motors are far less efficient than a regular induction motor such as the types used in about any other DW. The GE style SPM is easily the least efficient motor EVER used in a home DW and is less that 20% efficient.
More torque does not equal more water moved, both style pumps use the same size impellers so in order to move more water you need more speed and the PSC motor is more powerful.
When GE started switching to the better PSC motors they were not Chinese, but made by Seimans and they are rated at 1.45 amp draw, GE later went to a Chinese supplier. But GE simply could meet energy standards with the original inefficient motor.
Many DWs do not wash tall items in the corners of the top rack including, but not limited to, ALL GE DWs with a wash tower, All MT RR DWs, WP built Tall Tub DWs and many other DWs. I have been repairing DWs too long and have heard hundreds of complainants about this problem, just last Friday a customer was telling how things don't get clean in the corners of her basic GE DW with the older SPM, and of coerce I thought of you as she was telling me this, LOL.
Hope you get a chance to visit and we can do some testing or post some videos of your results, John. |
Post# 595036 , Reply# 55   5/8/2012 at 08:59 (4,367 days old) by chris74 ()   |   | |
This would be so great... To see the display and hear the sound that it makes... |
Post# 595042 , Reply# 57   5/8/2012 at 09:42 (4,367 days old) by william637 (Damp pants? Not a chance. )   |   | |
Looks like I have my memorial day weekend cut out for me - I'm going to clear my work table of the kitchenaids and hook up the 1200 and the 2800. Right now I am planning on blocking the spray from the lower rack with sheet pans placed as horizontally as possible, or just some heavy loading of pots.
Are there any specific tests (soils, objects, placement), etc. that anybody wants to see? I am planning on testing the 1200 with the original pump (with the small leak), and the 2800 with the new pump assembly.
As a side note, I enjoyed your post bwoods, but I think you might be off just a little regarding pumps/flow.
" ....result in greater flow of a fluid, even if the velocity of the stream remains the same."
As the size of the tubing to the nozzles, and the nozzle openings themselves are constant, flow and velocity are directly related. I.E. velocity can not increase without flow increasing, and vice versa.
Generally, HP changes in pumps are either a) to handle differences in head pressure developed or b) to drive different size impellers / housings. If your downstream head requirements are the same, the pump impeller and housing are the same, and the rpms are the same, then a using another motor with a higher HP does not result in greater flow.
I will point out that Fluid Mechanics was my least favorite subject in college (well, after control theory at least), and it has been years since I cracked that book. If I have stated the above incorrectly, please correct me.
Post# 595201 , Reply# 59   5/8/2012 at 23:36 (4,367 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Barry you need to get some facts together not just a bunch of your opinions if you want to have serious discussion. The 1.45 amps is printed on the Siemens motor and my testing verifies this rating. Ge started to abandon those crappy motors almost 20 years ago on their better model DWs.
Yes the old GE SPM do put out OVER 400 Watts of waste heat. What seems sensible to you does not make it true. As refrigerators have moved away from SPMs for fans power consumption has in most cases gone down 25-30 watts to 4 watts and the new motors have more starting torque. And even though the old GE SP DW motors were simple they probably had 20 or more times the failure rate of the newer PSC motors, in fact I can not recall a single instance of one of the newer motors failing. The SPM all though the late 1980s on had serious problems with loose fans and open windings, we saw hundreds fail.
One of the most common problems with the old SPM was VERY LOW STARTING TORQUE. Ask ANY GE repair person how many hundreds if not thousands of GE DWs with SPM that would not start because the motor is so weak that it could not overcome the water seals friction. We did and still do many of these every month where we have to turn the HUGE fan by hand to get it started again every time someone lets a GE DW sit unused for a few weeks.
And your ridiculous notion that water will travel horizontally a foot or more and then jump straight up into a glass in the corner of a rack,,,,,, You need to prove this as many here have seen DWs work with plastic fronts or even watching a lawn sprinkler will show that nothing like this ever happens, maybe in a different universe or planet LOL. |
Post# 595383 , Reply# 61   5/9/2012 at 20:43 (4,366 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Really not worth responding to Barry, almost every statistic you made in you last post just changed, I won't even try to keep up with your changing opinions.
I will let Mark do some testing later this month, eventually when I get my WALL OF DISHWASHERS installed we will do some real comparisons. But I should really know better than debate someone that also thinks that the GE series wound disposers were a great product LOL. |
Post# 901895 , Reply# 64   10/5/2016 at 15:22 (2,756 days old) by chetlaham (United States)   |   | |
Adding my 2 cents here I think what might be behind Mr. Bwood's observations are the fact the new style pumps have slimmer, redesigned bodies. This does not appear to make much of a difference in low water models that have a restricted wash arm orifice, but in older models with a metal wash arm and partial telescoping tower with a full opening (to the pump outlet) I do notice less water pressure.
I did do a test once where I placed a newer style motor on an older wide body pump and from my observations the water pressure was equal to what had been in there prior (old motor and old pump body). Also, I want to point out that the listed amp draw by itself for both motor means little. First the listed current draws are practically estimates, anticipated values under maximum specified conditions. That is current draw under a listed rpm driving a listed torque under listed voltage. (Think laboratory conditions). Come real world the motor will be driving more or less (usually much less) than what was asked for when building said motor, and thus its current draw will certainly vary in use from its listing. By how much is often best answered by a clamp on amp meter. The values listed on any appliance are more along the lines of worst case scenarios telling an electrician how to size the circuit for code purposes. Which motor received the worst case fudge factor is hard to say without testing. Second current draw on a motor is not just watts, but a combination of power factor (VA) and watts (W). Its possible to have a low power factor motor drawing lots of current in the form of VA with less current dedicated to watts (torque x speed and heat), and its possible to have a motor drawing little power factor (reactive power) while being mostly all watts (heat and torque x speed). As mentioned, watts are subdivided into two categories: output power and waste heat. It certainly is possible that the shaded pole motor is putting out 100 watts of rpm x torque, 250 watts of heat (3 amps) and the remaining 2.5 amps being nothing but reactive power which gives off no heat or torque. |
Post# 901897 , Reply# 65   10/5/2016 at 15:40 (2,756 days old) by chetlaham (United States)   |   | |
Post# 901928 , Reply# 66   10/5/2016 at 20:02 (2,756 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
My observations about dishwasher motor power consumption come from placing an amp meter on the leads to the motor. The newer style GE motors to drawl only about 1 1/2 A roughly 150 W. The older style shaded pole motors do you draw nearly 6 A or around 600 W of power.
Your claim that 250 W of power just evaporates as reactive power don't make any sense you should explain it to the power supply people Lol. I can assure you that all 600 W is either going into pumping water or heat it's that simple really. Thanks for reviving this fun old interesting thread. |
Post# 901938 , Reply# 67   10/5/2016 at 20:47 (2,756 days old) by Johnb300m (Chicago)   |   | |
I don't know what the waste heat rate was of the SPM. But as a kid, I was able to touch the running motor with my hand. If it was in excess of 60 or 100 watts, I doubt i'd be able to touch it.
Granted it blew off tons of heat, but c'mon, near 400 watts of waste heat? That's ridiculous. It would've melted the plastic tub after time at that rate. They certainly had low starting torque.... If any. In fact, many GE dw manuals had instructions on how to unstick a stuck SPM pump. As for that missing wattage loss? It's possible a lot of power went to actually driving that giant sheet metal fan. Another point too, to reiterate.....is.... As crappy as a motor as GE put I millions of dishwashers.....they were surprisingly market competitive for many decades. |
Post# 901939 , Reply# 68   10/5/2016 at 20:49 (2,756 days old) by chetlaham (United States)   |   | |
6 amps does not automatically equal 600 watts.
"Your claim that 250 W of power just evaporates as reactive power don't make any sense you should explain it to the power supply people Lol. I can assure you that all 600 W is either going into pumping water or heat it's that simple really." I never said that. Notice how I clearly made the distinction between the two by using the term "watts" and "VA". 250 Watts, which would be restive looses within the motor (heat radiated into space) having nothing to do with reactive power. "you should explain it to the power supply people Lol" Pure assumption... |
Post# 902001 , Reply# 69   10/6/2016 at 09:39 (2,755 days old) by chetlaham (United States)   |   | |
Not to confuse, but this is a good starting point.
"The disadvantages of shaded pole induction motor are Low power factor. The starting torque is very poor. The efficiency is very low as, the copper losses are high due to presence of copper band. The speed reversal is also difficult and expensive as it requires another set of copper rings." www.electrical4u.com/types-of-sin... Page 10 compares the different types: www.tcf.com/docs/fan-engineering-... As stated in both, and as I have long known, the power factor of a shaded pole motor is not unity but rather only 50 to 60%, or .5. This automatically means it is physically impossible for that motor to be generating 500 watts of waste heat with only 5.5 amps. Reactive power: en.wikipedia.org/wiki/AC_power... I will post more to back up my claims latter. |
Post# 902017 , Reply# 70   10/6/2016 at 11:44 (2,755 days old) by Johnb300m (Chicago)   |   | |
I remember seeing some comments on whether the older Hot motor was shaded pole or not.
Just wanted to show for the audience, straight from GE themselves, the old motor was indeed shaded pole. And they refuse to horsepower rate their motors.
Post# 902023 , Reply# 71   10/6/2016 at 12:39 (2,755 days old) by chetlaham (United States)   |   | |
Post# 902024 , Reply# 72   10/6/2016 at 12:40 (2,755 days old) by chetlaham (United States)   |   | |
Post# 902025 , Reply# 73   10/6/2016 at 13:02 (2,755 days old) by chetlaham (United States)   |   | |
Ok, good news. I explained it and asked the power people as one of them was able to test a similar shaded pole motor. As suspected, the motor's waste heat is well below 500watts with the extra current draw being explained by a low power factor:
forums.mikeholt.com/showthread.ph... |
Post# 902063 , Reply# 74   10/6/2016 at 18:48 (2,755 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 902064 , Reply# 75   10/6/2016 at 18:58 (2,755 days old) by chetlaham (United States)   |   | |
Excluding resistors and light bulbs, AC amps does not equal watts. Sure the amp meter does not lie, but there is much more to that number.
www.rapidtables.com/electric/Powe... |
Post# 902065 , Reply# 76   10/6/2016 at 19:00 (2,755 days old) by chetlaham (United States)   |   | |
Post# 902067 , Reply# 77   10/6/2016 at 19:10 (2,755 days old) by Johnb300m (Chicago)   |   | |
Fascinating thread Chet, but there doesn't seem to be a conclusion.
Did I miss it? Am I to understand the SPM would put out around 200w of waste heat? That's still ridiculous lol. Silly GE. I suppose nobody cared back then. And the market for quiet dishwashers is likely what really pushed them to PSC. |
Post# 902072 , Reply# 78   10/6/2016 at 19:40 (2,755 days old) by chetlaham (United States)   |   | |
Thanks, and lol, like many threads on that forum it does get lengthy. But basically we are trying to find the exact values, or at least those close to them with the information given. An actual power factor reading done by a kilowatt meter can help narrow it down, and knowing the amount of power the impeller and fan consumes will give exact numbers. However in so far the estimated waste heat is around 200 watts.
I am sure the number will get more refined and I will post them as they do. Not going to give up this easily, Ive always wondered about it but never had the guts to ask. |
Post# 902091 , Reply# 80   10/6/2016 at 22:35 (2,755 days old) by panthera (Rocky Mountains)   |   | |
that motor efficiency has improved over time. It is, however, worth noting that shaded pole motors do have a few advantages over some other designs which can, under certain circumstances, justify their use despite lower efficiency. 1) Stalling out doesn't burn them out. 2) Super simple: If it ain't there, it can't fail. 3) As long as they are lubed, they have an indefinite life expectancy. As to our Twenty-Eight Hundred, the original motor has now run daily since 1984 with neither shaft leak nor broken chopper (a genuine weakness). That's not bad when you consider she's on her third mainboard and calrod. |
Post# 902093 , Reply# 81   10/6/2016 at 22:55 (2,755 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is going to be around 375-500 watts, when you find out the exact # let us know, I have worked on enough of these to know what I am talking about.
The great thing about these crappy energy hog motors was they were great at drying up all the water that leaked at the trip shaft seal and even the main pump seal, I have seen many GE DWs that had leaked for years and the leaks went unnoticed because all the hot air blowing around dried up the water, if only they had directed the hot air through the DW chamber they could have left out the heating element for the dry cycle. |
Post# 902120 , Reply# 82   10/7/2016 at 09:24 (2,754 days old) by panthera (Rocky Mountains)   |   | |
For calculating Watts on an AC motor: P(W) = PF × I(A) × V(V) Somebody will have a better figure, but if I recollect properly, this motor has a power factor of about .85. So - If the motor draws 6A @120VAC, then we're looking at 612 watts. Now, I don't wish to be pedantic, but 100% of the work done by that motor is, ultimately, going to be heat. John's in the ball park on this. hell, anybody who's seen the fans on these knows that. And, I LIKE shaded pole motors. Actually, the Twenty-Eight Hundreds have a better power factor correction that people might expect - look at the power supply for the brain on them. I'd not be surprised it things add up pretty close to 1 in the end.
Post# 902131 , Reply# 83   10/7/2016 at 11:52 (2,754 days old) by chetlaham (United States)   |   | |
Post# 902137 , Reply# 84   10/7/2016 at 13:48 (2,754 days old) by panthera (Rocky Mountains)   |   | |
That would be a real world way. Anyway we cut it, these motors are horribly inefficient. And loud (blower). Still, over thirty years of constant service (I do re-oil the felt pad as per GE instructions every year or so) suggests they did get something right. Would I replace it with the capacitor split-phase induction design if it were to fail? Yes. Until then, it works well and makes a happy sound. |
Post# 902162 , Reply# 85   10/7/2016 at 16:39 (2,754 days old) by chetlaham (United States)   |   | |
No, trust me, I agree with all you guys. A shaded pole motor (even in the 70s and 80s) was RARELY used in anything larger than a box fan due to the weight and inefficiency. I could be wrong in that some furnaces might have been SP, but thats it that I know of. No one in there right mind would make a 1/6 shaded pole motor, but I guess GE did. Part of me is saying it might have been marketing (think vacuum cleaners) where 5.5 amps looked better than 2 amps, but ultimately those decisions remain as secrets buried deep in GE's past.
Question. For you guys who know GE DW, any idea how much power the impeller itself uses to pump water? Im guess is at 100-150 watts, but be wrong in that regard. As for myself I like the PSC a LOT more than the shaded poles. Quieter and no wind blowing about lol. Plus the new pump bodies make rinsing a heck of a lot better. |
Post# 902259 , Reply# 86   10/8/2016 at 09:05 (2,753 days old) by panthera (Rocky Mountains)   |   | |
One of the great things about the tremendous advances in metallurgy, manufacturing and electronics is the range of choice we have, today. Back in the 1970's, an electronically controlled motor - Philips had them in their washers, for instance - was a rarity. Today, we expect 'digital' motors to run at 100,000rpm + without the slightest hick-up. There are reasons we still use them, though: As long as they're lubricated, they have the longest life expectancy of any electric motor). Run in very very cold and very very hot environments, as well in environments in which enormous temperature variations over a short period of time are normal. Always start in the same direction (I'm not including the switched wire loop versions in this). Self-starting. Can be built as synchronous motors (I'm not getting into that discussion again). Many can be speed controlled by super-simple electronic circuits. Don't burn-up when stalled. As close to silent, when properly built, as a motor can get. Easy to magnetically shield. Super easy to use the stator windings as a transformer. Cheap, cheaper, cheapest to build.
Disadvantages - power PF without correction. Poor (that's an understatement) starting torque, lower efficiency than many other designs. Shaded pole motors were and are an answer for applications in which certain needs take priority. Inexpensive to build. Reliable - if it ain't there, it can't break down. Capacitors do have a limited lifespan and aren't tolerant of the high heat these motors can put away without difficulty. Eventually, no doubt, we'll see more efficient motors, but for the moment they still fulfill a market niche. Whether GE really needed to use them for dishwashers is a question I think we'll all have forever. |
Post# 902264 , Reply# 87   10/8/2016 at 10:12 (2,753 days old) by chetlaham (United States)   |   | |
Agree with all the above. Everything has its plus and minus and thus its own niche.
I can't speak for GE's choices, but one thing is for certain: GE not only managed to put millions of descent dishwashers in homes all over the world, but inspired countless children to become future engineers and appliance collectors. One of the earliest memories was playing around with a pot-scrubber and latter taking apart a GSD500D. Good times lol ;) But no doubt it was GE that started my interests in appliances and consumer electronics. It was always fun to toy around with their products. |
Post# 902310 , Reply# 88   10/8/2016 at 19:16 (2,753 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
GE used these motors for one reason and one reason only, They Were The CHEAPEST Motor To Build That Could Do The Job.
Every other DW manufacturer used a better MORE durable motor in their DWs including companies like D&M.
You are correct that these motors are simple, but simple does not mean they are necessarily more durable, because they run so hot and had cheap sleeve bearings and were poorly balanced I have no dough that most newer designs will outlast these SPMs. You are correct that adding a capacitor adds one more thing that can fail, but when you consider that modern capacitors on appliance motors have a life span of at least 50 years it really does not matter, LOL. I think I have seen one bad capacitor on a new style GE DW motor in the last twenty years.
Yes I agree Chet, that GE did introduce a lot of American homes to the work saving convenience of a built-in DW buy building them so cheaply and getting new home builders to put them in homes. A local development near here where Kettler Brothers built 1800 homes from 1963-1969 all had GE kitchens and they all had a GE BIDW. One of the men that worked for the builder said that GE sold them the DWs for $59 each.
The other great thing about GE selling all these cheap DWs to builders was the replacement market after they rusted out and the motors and pumps failed after 5-15 years, by that time most consumers were hooked and went out and bought a good DW, the reps at WP, KA and Maytag loved GE for this, and GE even put Waste-King on the DW map because of the way GEs rusted out people were looking for something that would not rust, LOL. |
Post# 902330 , Reply# 89   10/9/2016 at 00:03 (2,753 days old) by Johnb300m (Chicago)   |   | |
Post# 902357 , Reply# 90   10/9/2016 at 08:56 (2,752 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi John, it has nothing to do with hate and I though my post was pretty positive, using these cheap to build motors did allow GE to sell lots of consumers on having DWs, but there is not one redeeming quality of the SPM compared to the newer ball-bearing PSC motor for use on GE DWs, except the ability to evaporate water under the DW from leaks from GEs crappy leaky trip shaft seals.
In the nearly 20 years the newer PSC motors have been used in GE DWs our firm has seen one bad capacitor and one motor with a slightly noisy bearing, when I compare that with literately hundreds of SPMs on GE DWs that had loose fans, bad bearings, and open motor winding's I simply cannot say these SPMs were more durable. |
Post# 902372 , Reply# 92   10/9/2016 at 11:15 (2,752 days old) by chetlaham (United States)   |   | |
Well, if I may... I think this might be a bad taste from the early 90s up to the 2000s still lingering. In the 80s when GE's DW division peaked in every way possible, the shaded pole motors did not fail more than any other DW motor, in fact Id argue the least outside of KA. I have seen hundreds, if not thousands of mid 80s pot-scrubbers chucked out with the motors running and looking like they are mint. Also, the leaks you bring up were very, very common to the mids 90s-2000s GEs (hundreds had to be scrapped after only 8 years of use where I live, and most of that era always have crusty drain solenoid brackets), but rare on the 80s versions.
It was not so much the design, but run away cheapening and crap CC in the 90s that gave GE so many bad raps. |
