Thread Number: 40125
FOUND AN OLD MAYTAG DISHWASHER!!!! |
Post# 593972   5/3/2012 at 16:34 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593974 , Reply# 1   5/3/2012 at 16:36 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593975 , Reply# 2   5/3/2012 at 16:38 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593976 , Reply# 3   5/3/2012 at 16:39 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593977 , Reply# 4   5/3/2012 at 16:41 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593978 , Reply# 5   5/3/2012 at 16:42 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593980 , Reply# 6   5/3/2012 at 16:43 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593981 , Reply# 7   5/3/2012 at 16:45 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593982 , Reply# 8   5/3/2012 at 16:47 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593983 , Reply# 9   5/3/2012 at 16:48 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593984 , Reply# 10   5/3/2012 at 16:49 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593985 , Reply# 11   5/3/2012 at 16:51 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593986 , Reply# 12   5/3/2012 at 16:54 (4,374 days old) by rollermatic (cincinnati)   |   | |
way in the back! since it's a horizontal pump even if the seal is bad the motor is most probably fine!
and i did find a pump seal for it (i think) at repair clinic .com. gonna call larry tomorrow too in parma and check on them. might as well garb a seal if there are any out there. hard to get to the motor though as entire bottom is covered by a metal plate that must come off. no time to do it today! will come back to this one later this summer! |
Post# 593988 , Reply# 13   5/3/2012 at 16:56 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593989 , Reply# 14   5/3/2012 at 16:56 (4,374 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 593990 , Reply# 15   5/3/2012 at 16:58 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593991 , Reply# 16   5/3/2012 at 17:00 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593992 , Reply# 17   5/3/2012 at 17:01 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593993 , Reply# 18   5/3/2012 at 17:02 (4,374 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 593994 , Reply# 19   5/3/2012 at 17:02 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 593998 , Reply# 20   5/3/2012 at 17:06 (4,374 days old) by rollermatic (cincinnati)   |   | |
the only thing wrong was the faucet connector. i see the hoses are clamped on making the plastic outer cover not fit on it.
when i loaded it in my jeep water did drip out the bottom. i'm hoping this is from a loose hose or the faucet connector and not the pump! gonna put some water in it and try it out. since it's a horizontal pump even if it leaks i won't damage the motor! later this summer i'm gonna pull that bottom cover off and tear out pump and motor and see what it's made of! since this post will probably be gone by then i will do a new post when i tear into it! |
Post# 594003 , Reply# 21   5/3/2012 at 17:13 (4,374 days old) by rollermatic (cincinnati)   |   | |
I FORGOT ALL ABOUT THAT FULL SIZE SPRAY ARM ON TOP!!! WILL GET A PIC OF IT LATER TONITE.
excuse typo's in this post but i am runnin out the door and i just got back with it an hour ago and wanted to get this on quick! this was a very spur of the moment trip but for 20 bucks i could not turn it down! 1972! thanks! sounds good to me! they were all built like trucks back then! this is the heaviest one i have ever attempted to lift and load! thanks again! |
Post# 594024 , Reply# 22   5/3/2012 at 19:07 (4,374 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
That's a fun machine - you'll be amazed at how much quieter this motor & pump is compared with the later belt-drive machines. It's still rather loud during drain but circulation is noticeably less hair-raising. This looks to be the first revision of their first models, earlier ones had trouble with leaks around the door and even wash arms that hit the bottom of the door ever so slightly that it would wear away the porcelain and eventually a rust hole would develop. Poor Maytag. While Maytag never really could dispose of a pea or a stray noodle, this design caught everything in the figure eight strainer and saved it for you to pick out when the cycle finished. Saved for tomorrow night's stew, Maytag encouraged thrift in homemaking, automatically! |
Post# 594025 , Reply# 23   5/3/2012 at 19:07 (4,374 days old) by bajaespuma (Connecticut)   |   | |
That there is my daily driver silverware basket; nothing I've ever seen is able to hold chopsticks in place for dishwasher washing. John LeFever said that there were a lot of complaints with that basket because of water retention and release on removal but I love that thing. Congratulations on a wonderful find. |
Post# 594044 , Reply# 26   5/3/2012 at 21:09 (4,374 days old) by rollermatic (cincinnati)   |   | |
that faucet adapter is the large diam. size actually.
i do like the wood top. but after i tear this one down and put it back together and clean it up, maybe put in a new seal, it will be stored like most of my machines. so it won't get much "chopping use" from me. but then i'm not much of a cook either ha ha! but i am curious here, why would a wood top on a dishwasher not be very "p.c."?? granted, i am probably the most un politically correct guy around these days but i have to ask!? |
Post# 594057 , Reply# 28   5/3/2012 at 23:08 (4,374 days old) by alr2903 (TN)   |   | |
Use mineral oil on your wood top. If its going in storage over the hot summer be very generous with the oil. alr |
Post# 594076 , Reply# 29   5/4/2012 at 00:49 (4,374 days old) by AutoWasherFreak ()   |   | |
You can also use linseed oil on the wood top. I used it on my WP portables that I had in the 80's and 90's. |
Post# 594077 , Reply# 30   5/4/2012 at 00:52 (4,374 days old) by AutoWasherFreak ()   |   | |
Forgot--nice dishwasher, harvest gold is my favorite appliance color! |
Post# 594106 , Reply# 32   5/4/2012 at 07:14 (4,374 days old) by william637 (Damp pants? Not a chance. )   |   | |
You will absolutely love that dishwasher. The reverse rack Maytag was a very clever and well thought out design to make sure the jets of water hit the soiled surfaces in the most effective way possible.
My first boyfriend had the TOL Maytag reverse rack - it was the next generation with the redesinged sump. It was all electro-mechanical push button control. One of the most beautiful machines I have ever seen. I probably should have stayed with him just for that. It was loud, but a beautiful loud (kinda like the B-52's at full volume).
Enjoy - and congratulations! |
Post# 594128 , Reply# 34   5/4/2012 at 09:58 (4,374 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These were in some ways better than the later MT BD machines but were very difficult to repair when built in. This DW like later MTs and all KAs 15-23 and most WPs uses the same main water seal, I buy them from MT by the bag full. Your machine also has the later GE main motor The earlier version had a GM built Delco motor Good Luck with it, If you want to call me and I can point out the various areas of possible problems. |
Post# 594132 , Reply# 35   5/4/2012 at 10:04 (4,374 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 594148 , Reply# 36   5/4/2012 at 11:55 (4,374 days old) by mickeyd (Hamburg NY)   |   | |
Great Maytag continuity of design--the way the buttons resemble those on the washers. Perfect close-up.
These older Maytags, the conventionals, the automatics, the DW's are so steady, sure, and confident--never say die. I love them, and their low rumble of power.
Pete, when you say this machine, once restored, will go into storage, I was wondering what your long range plans are. Are you going to have a museum-like display some day, like John and Ted are planning, or will there be a big sell-off? You have so many amazing machines.
The classy spotless Italian restaurant I worked at, Minillo's of Cleveland, butchered its own meat on a wooden block just like the one on your Maytag, and then, after a good scrubbing, it was disinfected with Clorox. Never had any health/germ/food poisoning issues.
Post# 594153 , Reply# 37   5/4/2012 at 12:08 (4,374 days old) by turquoisedude (.)   |   | |
Great find, Pete! The Harvest Gold finish brings back lots of memories!!
I always liked the control panel the way the dial was set into the door of these models. Hope you have lots of fun with it and if you ever need spare racks or a cutlery basket (new blue ones, though), I have 'em and I need to make some room in the garage.... |
Post# 594159 , Reply# 38   5/4/2012 at 12:33 (4,374 days old) by rollermatic (cincinnati)   |   | |
this must be a popular machine here! i had a hunch it was worth driving 2 hours to pick up and bring back! and for 20 bucks!
loved the "rant" appliance guy, i can do those quite well myself! i figured it was un p.c. due that it was a "real" wood top. i work at home depot and i see what we sell for wood these days! combo, did you mean that i can use the same seal on this maytag as i could on any kitchenaid from 15-23? great! thanks to all for the tips on preserving the top. i may keep this one in the kitchen for awhile and use it since everyone says it is such a great machine. i have 8 of my favorite machines in the kitchen, from g.e. mobile maid to kitchenaid kd2-p but maybe i'll move one out. i am not a meat cutter type so i would never use that chopping block for meat but it sure looks pretty and so nostalgic. and i agree, the harvest gold is great! what will i do the machines in the long run? i say i am done collecting but then i keep adding on. i will probably have to thin out my kitchenaid collection a bit and if i "croak" for some reason i have instructed my best friend to get ahold of automaticwasher.org and everything will be given away! what a funeral!!!! "come and get em"!!!! |
Post# 594161 , Reply# 39   5/4/2012 at 12:35 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 594162 , Reply# 40   5/4/2012 at 12:36 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 594163 , Reply# 41   5/4/2012 at 12:38 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 594165 , Reply# 42   5/4/2012 at 12:42 (4,374 days old) by rollermatic (cincinnati)   |   | |
Post# 594168 , Reply# 43   5/4/2012 at 12:45 (4,374 days old) by rollermatic (cincinnati)   |   | |
i have another question please.
why is it called a reverse rack? is it because the top rack is so deep in height that plates can be put in it as well as in the bottom? are plates normally loaded in the top on these maytags? gonna try to get this one water tested sometime this weekend. am very curious as to how it runs. you guys have given so many "thumbs up" comments i can't wait to try it out! thanks! |
Post# 594173 , Reply# 44   5/4/2012 at 13:02 (4,374 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Because it's loaded "in reverse" of what you would normally do. I.E.... plates and silver in the top rack (leaning back instead of forward) and glasses, cups, bowls, pots, etc in the bottom rack.
So this IS your first Maytag DW Pete? YAY!
FYI... in fact after seeing your post for this DW, I (foolishly) went to that evil Craigs list and searched for Maytag dishwashers. Found an older built in for $75 and a newer (but still reverse rack) portable for $40. The Maytag gene runs strong in my veins, so I drove to Santa Monica last night to pick it up and now I have one too! What the hell do I need with ANOTHER dishwasher?!?! UGH! LOL
Kevin |
Post# 594174 , Reply# 45   5/4/2012 at 13:10 (4,374 days old) by william637 (Damp pants? Not a chance. )   |   | |
Post# 594207 , Reply# 48   5/4/2012 at 15:53 (4,374 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 594220 , Reply# 49   5/4/2012 at 16:39 (4,373 days old) by rollermatic (cincinnati)   |   | |
i think i have every brand except a westinghouse and am always on the lookout for one of those.
i have another maytag but it has a plastic tub and is not belt driven. direct vertical mount pump/motor. it's a maytag jet clean. i assume from the 80's or possibly 90's. i keep it in storage as i hate to pitch it but i don't consider it anything really worthwhile. and if i remember the top rack is not deep enough for plates and the silverware is on the bottom. congrats on your's also kevin! craigs list is where i found this one and most of l my others too! e bay is great too at times. thanks for the info on the door latch, white tub. i haven't plugged it in yet so i have no idea what it is like electrically. hopefullt in a couple days here. |
Post# 594268 , Reply# 50   5/4/2012 at 20:27 (4,373 days old) by jakeseacrest (Massachusetts)   |   | |
Post# 594283 , Reply# 51   5/4/2012 at 22:08 (4,373 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 596244 , Reply# 54   5/13/2012 at 19:13 (4,364 days old) by rollermatic (cincinnati)   |   | |
i was able to work on this maytag and water test it tonite! it runs great and doesn't leak!
the woman said the problem was the faucet hookup but it was really the fill valve. it was completely clogged and no water would enter. i took it all apart, cleaned it and gave it some new screws! put it back on and it works fine! here it is back in but not screwed down to frame yet. |
Post# 596246 , Reply# 55   5/13/2012 at 19:24 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596247 , Reply# 56   5/13/2012 at 19:27 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596248 , Reply# 57   5/13/2012 at 19:31 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596249 , Reply# 58   5/13/2012 at 19:35 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596250 , Reply# 59   5/13/2012 at 19:39 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596252 , Reply# 60   5/13/2012 at 19:41 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596253 , Reply# 61   5/13/2012 at 19:42 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596255 , Reply# 62   5/13/2012 at 19:43 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596256 , Reply# 63   5/13/2012 at 19:44 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596257 , Reply# 64   5/13/2012 at 19:46 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596258 , Reply# 65   5/13/2012 at 19:51 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596259 , Reply# 66   5/13/2012 at 19:54 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596260 , Reply# 67   5/13/2012 at 19:58 (4,364 days old) by rollermatic (cincinnati)   |   | |
Post# 596262 , Reply# 68   5/13/2012 at 20:03 (4,364 days old) by rollermatic (cincinnati)   |   | |
and i wanted to add it to this thread instead of posting a new one. gonna fine tune this machine a bit, clean it up some more, and actually use it for awhile!
oh i didn't mention that it has the fastest spray arm rotation i have ever seen. between 3 and 4 revolutions per second! i had to quickly open the door to believe it! that spray arm really moves! and it takes about 10 seconds after pump staerts for it to get up to that speed! seems like these old 72 maytags were really built well! it's 40 years old and no leaks and i can even still get a seal for it! what more could i ask for 20 bucks! i like it! |
Post# 596366 , Reply# 70   5/14/2012 at 07:08 (4,364 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Cool Peter glad you got it working, these early MT DWs were difficult to work on, in the case of the built-ins you had to remover the DW from under the counter to access the pump [ kind of like a new Bosch or Asko or Meile LOL ] and on the portable you still have the cabinet to deal with. I would be careful getting any lubricant on the hose connections as a frequent problem MT had on these early DD RR machines was the hoses would BLOW off the pump outlets and cause a nice flood as the machine would go through the rest of the cycle and dump all the water on the floor, at least with a portable you will usually spot the leak instantly LOL. |
