Thread Number: 43936
Persil Detergent Confusion |
Post# 646043 , Reply# 1   12/12/2012 at 19:14 (4,124 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
I found out I hated the pearls as they VERY easily roll all over the place and out of the cup! When they do they sit on the concrete floor - absorb moisture then burst making them impossible to sweep up!
Also I only ever liked the results in my front loaders, never saw a good wash come out of my traditional top loaders ever. I would stick with the pure powder, the megapearls is just a marketing gimmick they are basically the same formula and I have seen megapearls advertised with anti graying, which is just good use of sodium carbonate and zeolites. Any good detergent will do that! |
Post# 646090 , Reply# 2   12/12/2012 at 21:53 (4,124 days old) by labboy (SD, CA)   |   | |
Post# 646190 , Reply# 3   12/13/2012 at 11:21 (4,123 days old) by mrb627 (Buford, GA)   |   | |
It seems a shame that for as expensive a detergent as Persil is, it requires any supplimental chemical additives. When I use Persil, I have to add a small quantity of Biz to get the results I desire. Regardless of how much or little I use of the Persil. Not sure I will restock it when I run out this time.
Malcolm |
