Thread Number: 44443
Adding cord to dishwasher |
Post# 652908 , Reply# 3   1/13/2013 at 08:59 (4,113 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Are all of your kitchen outlets GFI-protected? You need to try it on an outlet that is not a GFI outlet. |
Post# 652916 , Reply# 4   1/13/2013 at 09:35 (4,113 days old) by dj-gabriele ()   |   | |
May ask why isn't GFI protection compulsory on all the circuits? That could lead to very unsafe situations if only a small electric leak is present |
Post# 653113 , Reply# 8   1/13/2013 at 16:25 (4,113 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
GFI Breakers are unnecessary for appliances with three wire cords as you are automatically protected from a shock by a malfunctioning appliance.
Refrigerators should not be used on GFI circuits unless you like the idea of coming from a vacation to a refrigerator that has shut down the GFI breaker with all you food rotting inside.
Heating elements in US DWs that have plastic tanks are usually not grounded, so it could not cause the GFI to trip, at least not until there is a water and detergent solution in the DW that could conduct power from a shorted element to a grounded part but even this is unlikely on most DW designs as usually no metal parts of the pump motors touch the water. |
Post# 653346 , Reply# 17   1/14/2013 at 17:28 (4,112 days old) by kb0nes (Burnsville, MN)   |   | |
The only guess I have is that the stock molded plug on cord you bought was somehow leaky. Provided your connections in the unit were solid and clean replacing that end probably didn't fix the problem.
I have seen the molded end of a cord fail several times, although they usually failed open, not shorted in anyway. When the cord end was molded its possible that something could have allowed a small current path inside the plug. It takes very little current to trip the GFCI, I think the test standard is .05 amps. I often lop off the molded ends of cords and replace them with a good reusable plug/socket (good is Leviton, Hubble etc). Especially for any high current applications. The molded plugs sometimes get hot and burn up when used in high current applications. Another benefit is if the cords are used somewhere cold. On the female end of extension cords the molded plastic gets hard in the cold. In MN winters you can't plug your engine heater into an extension cord well below zero sometimes! |
Post# 653465 , Reply# 18   1/15/2013 at 06:31 (4,111 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Frigidity causes rigidity. |
Post# 653853 , Reply# 19   1/16/2013 at 23:41 (4,109 days old) by kb0nes (Burnsville, MN)   |   | |
