Thread Number: 48268
1955 Kenmore dishwasher gasket |
Post# 699564   8/28/2013 at 17:48 (3,865 days old) by classiccaprice (Hampton, Virginia)   |   | |
As you may remember, I got a 1955 D&M built Kenmore dishwasher from Customline back in February. The top gasket around the lid is leaking when I run the machine. Right now I'm just using a towel to keep water from running down the side of the machine, but I am considering replacing the gasket. Does anyone have any recommendations of where to look for something that could work? Thanks! |
Post# 699584 , Reply# 1   8/28/2013 at 20:00 (3,865 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Will, you shouldn't have to replace the original gasket. What I would try first is going to your hardware store and buy some closed cell foam. Make sure you buy closed cell and not open cell. The foam on one side should have peel off sticky glue so you can attach it to the lid. I would attach it to the underside of the lid edge where it meets the rubber gasket when the lid closes. This most likely will cure any leaks. It will slightly take more pressure to close the lid, but it will be worth it to have a leak free dishwasher.
Post# 699587 , Reply# 2   8/28/2013 at 20:09 (3,865 days old) by kb0nes (Burnsville, MN)   |   | |
I don't know what the profile if the original gasket is but you may want to take a look here:
www.mcmaster.com/#bulb-seals/=o9n... They could also be a good source for a closed cell foam tape as Robert mentions for use to augment the existing gasket. |
Post# 699590 , Reply# 3   8/28/2013 at 20:16 (3,865 days old) by classiccaprice (Hampton, Virginia)   |   | |
