Thread Number: 48682
motor with burnt start windings |
Post# 705251   9/25/2013 at 08:02 (3,864 days old) by vaclover (South Africa, Virginia)   |   | |
Is there any way to start a motor with burnt starting windings?maybe a circuit with a capacitor and relay in it?if there is please let me know |
Post# 705261 , Reply# 1   9/25/2013 at 10:51 (3,864 days old) by Travis ()   |   | |
I assume this is in reference to the start windings on an old refrigerator you have. You can't work around that. The compressor has failed. |
Post# 705264 , Reply# 2   9/25/2013 at 11:22 (3,864 days old) by kb0nes (Burnsville, MN)   |   | |
And if its a hermetic compressor you can't even wrap a rope around the pulley and pull ;)
Ultimately I think Travis is correct. The manufacturer would have used the simpler work-around instead of an additional winding if it would work, they don't like adding expense when its not needed! It the starter winding measuring as open? |
Post# 705275 , Reply# 5   9/25/2013 at 12:26 (3,864 days old) by vaclover (South Africa, Virginia)   |   | |
But wouldn't it be nice if I had a washing machine starting with a rope??lol imagine these rope gets tangled in the pulleys! |
Post# 705283 , Reply# 6   9/25/2013 at 13:12 (3,864 days old) by cfz2882 (Belle Fourche,SD)   |   | |
that old washer motor is likely a "split phase"type with a centrifugal switch to disengage the start winding once motor is at run speed-that switch may need cleaning/repair/adjustment if motor sometimes fails to start. |
Post# 705293 , Reply# 7   9/25/2013 at 14:10 (3,864 days old) by vaclover (South Africa, Virginia)   |   | |
Is it inside the motor somewhere?because you can see the motor shaft at the back? |
Post# 705321 , Reply# 8   9/25/2013 at 17:09 (3,864 days old) by epixstar128 (toledo)   |   | |
Might be able to start with a large hammer send power to run windings and just start hitting it with a hammer may work |
Post# 705323 , Reply# 9   9/25/2013 at 17:14 (3,864 days old) by epixstar128 (toledo)   |   | |
F12 is the same as r 12 not r134a |
Post# 705769 , Reply# 13   9/27/2013 at 19:30 (3,862 days old) by epixstar128 (toledo)   |   | |
I If there is any electrical diagram please snap a picture and post it on here |
Post# 705770 , Reply# 14   9/27/2013 at 19:38 (3,862 days old) by epixstar128 (toledo)   |   | |
Or just pictures of the compressor more pictures the better |
Post# 705886 , Reply# 16   9/28/2013 at 08:58 (3,861 days old) by epixstar128 (toledo)   |   | |
Pics of everthing i will help if i can worked on refrigeration systems for a living |
Post# 705919 , Reply# 19   9/28/2013 at 12:05 (3,861 days old) by vaclover (South Africa, Virginia)   |   | |
A 1/8th hp compressor!!imagine the size of the 1hp and bigger?I also want to know the contacts on the inside its inside the oil isnt it like if its in water?making a short or something? |
