Thread Number: 53453
Ge filter flo |
Post# 758192 , Reply# 1   5/19/2014 at 19:38 (3,628 days old) by mrb627 (Buford, GA)   |   | |
Post# 758193 , Reply# 2   5/19/2014 at 19:39 (3,628 days old) by Yogitunes (New Jersey)   |   | |
February 1978........
four hoses.....3 mounting screws.....and a rubber/leather belt clamp....15 minutes top! and this is a link to the pump..... are you sure it needs a pump?......normally putting the hose on the floor will not make it drain on its own, without some help in creating a siphon... I would take the back off first and make sure the clamps are secure from the motor to the pump........ and since your at it, I would replace the belt...save yourself time and headache since your removing the pump....your choice.....their only around 4.00 at AutoZone... attach some pics when you get a chance..... CLICK HERE TO GO TO Yogitunes's LINK on eBay |
Post# 758256 , Reply# 4   5/20/2014 at 00:50 (3,628 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 758881 , Reply# 5   5/22/2014 at 11:49 (3,626 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
I would just get the renter a good used replacement and scoop up that old filter flo.
As far as threatening to not pay rent, good luck with that. If they are really going to go that route I would let the renter find and pay for the replacement washer, then reimburse them for it. This way if there is any trouble with the newer washer, it doesn't fall on the owner. |
Post# 759195 , Reply# 7   5/23/2014 at 22:13 (3,624 days old) by tecnopolis (Ocala/Dunnellon, Florida 34481)   |   | |
