Thread Number: 54465
Need help with Whirlpool/Inglis compact washer... |
Post# 768465   7/6/2014 at 15:10 (3,553 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
I've finally found some time to replace the pump on this. I cant fiqure out how to get the "top" off, and subsequently, to get the surround off. I've unscrewed the back "hinges".
I understand from previous threads that these are built first and then the surrounds and tops added. I took off the temp and water level knobs, but can't get the programme knob off. Please lend me your experience... Guy |
Post# 768533 , Reply# 2   7/6/2014 at 18:17 (3,553 days old) by Yogitunes (New Jersey)   |   | |
stop where you are.....
pop the top.....from the right front, find and unplug the timer control wires leading down to the bottom.....disconnect the inlet hose from the splash shield.....disconnect the drain hose from the port at the back, there will also be a retaining screw/strap towards the front...remove the hose to the pressure switch..... lower the top back down.......and remove 2 screws at the bottom on each side, and two on the back.....you may need help, now, lift the whole body off the machine..... this will allow you to service the unit....you can also hang the wires over top and reconnect if you want to test the machine with it uncovered... any problems....let us know... we just did this to JammanJoe's machine at Jerry's wash-in.....check out reply number 16....pics 8 and 9 CLICK HERE TO GO TO Yogitunes's LINK |
Post# 768690 , Reply# 3   7/7/2014 at 07:47 (3,552 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
