Thread Number: 54478
Maytag Reverse Rack filling problem |
Post# 768676 , Reply# 1   7/7/2014 at 07:00 (3,552 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If you take your inlet valve apart you need to replace the fill valve rubber seats to have a good chance of getting it to work properly again. The other choice is to replace the inlet valve with a new one, these can still be found.
You may be able to get either the valve rebuild kit or a complete new valve from Modern Parts in Ohio, # 216-661-6966 |
