Thread Number: 5470
Maytag AMP--That &%#$@! T-Key!! |
Post# 116108 , Reply# 1   3/18/2006 at 22:21 (6,612 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 116121 , Reply# 2   3/18/2006 at 23:31 (6,612 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 116204 , Reply# 4   3/19/2006 at 10:08 (6,611 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Hi Austin ... oh boy; patience pays off! Do you think that maybe perhaps some more use will help lubicate the brake system and loosen it up a bit? |
Post# 116210 , Reply# 5   3/19/2006 at 10:36 (6,611 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 116283 , Reply# 6   3/19/2006 at 16:04 (6,611 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Austin, If you take the brake assembly apart you will find the break shoes are covered with grease, this is normal. The first time my brother and I worked on one of these washers, we thought it would be good to clean all the grease from the shoes and drum area. We had a real suprise the first time the tub stoped and the whole washer turned about half way around. Jeff
Post# 116321 , Reply# 8   3/19/2006 at 20:05 (6,611 days old) by unimatic1140 (Minneapolis)   |   | |
Hi Austin, congratualtions on getting through a big challenage like working on the AMP T-Key and related parts. That's not an easy thing to work on, sounds like you had a great success there, and its something to be very proud of. I would leave the clutch alone for now. It doesn't quite make sense that the motor would strain when empty, but it works fine when its full of water. I would wait and run a bunch of wash loads through it, sometimes these things work themselves out just by running the machine normally. The best advice I can give to you is not to over tinker with the machine until you've seen some wash run through it. |
Post# 116343 , Reply# 9   3/19/2006 at 21:37 (6,611 days old) by brettsomers ()   |   | |
i wonder if machines such as the AMP ever collected soil between the two tubs? |
Post# 116381 , Reply# 11   3/19/2006 at 23:07 (6,611 days old) by brettsomers ()   |   | |
i cant WAIT to see a vid of this thing washing a nice load! |
Post# 116383 , Reply# 12   3/19/2006 at 23:35 (6,611 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 116439 , Reply# 13   3/20/2006 at 07:57 (6,610 days old) by geoffdelp (SAUK RAPIDS)   |   | |
Austin ... HOORAY!! Did you figure out the water connections yet for the portable aspect? Did it come with the special coupling device? |
Post# 116494 , Reply# 14   3/20/2006 at 10:06 (6,610 days old) by rickr (.)   |   | |
