Thread Number: 54717
Maytag Jetclean Portable MDC4000 |
Post# 771150   7/15/2014 at 18:50 (3,563 days old) by jakeseacrest (Massachusetts)   |   | |
So I may have a developing issue. Ran a cycle on Normal tonight. As it was performing the final drain it stopped and I kept hearing a clicking noise from the control dial. Most of the water was still in it. I advanced the dial to other cycles and just clicking. So I took all the dishes out and towel dried them. About 15 minutes later I tried again to start it and it worked fine filling and draining as it should. What could be going on?
Post# 773410 , Reply# 1   7/27/2014 at 12:23 (3,552 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Hey,
I was trying to look for a pic of the control panel of your dw. I found this link about a model like yours clicking and not draining. Me thinks maybe something stuck in the pump that corrected itself when the unit went into re-circulation mode or maybe a timer problem. But this is likely a microprocessor model. Is it still acting up? www.applianceblog.com/mainforums/... |
Post# 773414 , Reply# 2   7/27/2014 at 12:31 (3,552 days old) by jakeseacrest (Massachusetts)   |   | |
