Thread Number: 58645
/ Tag: Classified Ad Finds
TOL 1st Orbital Maytag in ATL area |
Post# 812039   3/2/2015 at 20:02 (3,313 days old) by PeterH770 (Marietta, GA)   |   | |
First orbital... TOL... Aqua Power Fin 12...
CLICK HERE TO GO TO PeterH770's LINK on Atlanta Craigslist |
Post# 812062 , Reply# 1   3/2/2015 at 22:21 (3,313 days old) by 70series ( Connecticut.)   |   | |
This is an A712 which was of the helical design; one of the last with the long slow stroke. I don't believe the orbital Maytags had the Powerfin. |
Post# 812072 , Reply# 2   3/2/2015 at 23:35 (3,313 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Peter's correct, this is an Orbital transmission. You can tell by the smaller agitator skirt with the small fins in between the flex-fins.
A good friend of mine at the time bought one of these for her first home and it was the first time I got to use one. I had my set of turquoise 700's at the time and was shocked to see what Maytag had done to that beloved design. |
Post# 812075 , Reply# 3   3/3/2015 at 00:12 (3,313 days old) by A440 ()   |   | |
Most of these beauties were guaranteed to leak in no time..... You could bet you money on it! And sadly most did.
Post# 812103 , Reply# 5   3/3/2015 at 05:52 (3,313 days old) by appnut (TX)   |   | |
The first time I heard one with the new Orbital transmission short stroke was in like 1991 or 1992. It was like a part of me had been ripped out. No longer was there the zen-like soothing hum of Maytag. You still heard the hum of the motor, but it was shattered by the thunk thunk of the fast agitation back and forth. I'd already had the Lady Shredmore since October 1986 and knew a Maytag washer wouldn't be in my future--the short fast stroke. I did get my Dependable Care dryer December 1993 though. |
Post# 812191 , Reply# 6   3/3/2015 at 18:34 (3,312 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 812488 , Reply# 7   3/5/2015 at 20:25 (3,310 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Tom and I installed the first one of these that I saw run in person [ the customer was giving up on a Frigidaire WCI-61 and a 1954 GE dryer ] After Tom and I saw the pathetic agitation we decided we didn't need one.
MT was having water leaks from the main tub seal all through the 80s the new transmission did not have any thing to due with the increase of water leaks [ by 1990 WP-KM over took MT in reliability in top load washers and of coarse WP-KM were always ahead of MT in dryers in both reliability and performance ].
Overall the Orbital transmission was one of the best improvements MT ever made on the Helical drive washers , the only problem was the orignal agitator, but once they started using the load sensor agitator they finally had a washer that could turn over a large load AND an agitator that no longer destroyed clothing { a shorter stroke is always better for clothing than a long stroke ] And if you really wanted a higher performing MT HD washer I recommend getting the 50 cycle motor pulley, this pulley speeds up the agitation 15% and increases the high spin speed to just over 700RPMs so it is about the same as a new SQ TL Washer. |
Post# 812496 , Reply# 8   3/5/2015 at 21:39 (3,310 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 812517 , Reply# 9   3/6/2015 at 04:30 (3,310 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 812520 , Reply# 10   3/6/2015 at 05:18 (3,310 days old) by PhilR (Quebec Canada)   |   | |
