Thread Number: 59700
/ Tag: Vintage Dishwashers
KDS 18 Leak and Other Questions |
Post# 823240 , Reply# 1   5/13/2015 at 13:28 (2,884 days old) by chachp (North Little Rock, AR)   |
![]() 2
![]() ...but is it possible that the sound you hear during the Sani Cycle, that you think is a fine spray, is actually the heating element heating the water?
When mine is heating the water you can hear what sounds a little like a hissing noise. If you got a lot of steam and then the rinse started up I suspect that's what you were hearing. | ||
Post# 823241 , Reply# 2   5/13/2015 at 13:33 (2,884 days old) by turquoisedude (.)   |
![]() I'm not that well-versed in KitchenAid dishwashers, but have you noticed the heater functioning during the dry phase of regular wash cycles? If you can set the timer to the dry part of a regular wash cycle, try that to see if your heater is kicking in. I'm not familiar with the 18 series machines, but if there's an 'energy saver' switch, check it to make sure it's not stuck and overriding the dry heater.
That's all I got.... LOL | ||
Post# 823896 , Reply# 8   5/17/2015 at 15:43 (2,880 days old) by cuffs054 (MONTICELLO, GA)   |
I always thought that water was supposed to be in the sump to keep seals soft and block odors from coming through. | ||
| Post# 823920 , Reply# 9   5/17/2015 at 17:49 (2,880 days old) by stevet (West Melbourne, FL)   |   | |
But usually not more than a very small amount, plus between cycle segments, you would want to get out as much of the dirty water as possible. | ||
Post# 823926 , Reply# 10   5/17/2015 at 19:11 (2,879 days old) by cuffs054 (MONTICELLO, GA)   |
Wow, I didn't realize that. All my DW that I can remember as well as washer have had the corrugated hose. I will have to check it out. | ||
