Thread Number: 59849
1979 Hotpoint 1509/10 overhaul |
Post# 825102 , Reply# 1   5/25/2015 at 16:15 (3,250 days old) by ooversanwashers ()   |   | |
Will this be your daily washer after completion? Oh and do you have a lid for it? Thanks |
Post# 825107 , Reply# 4   5/25/2015 at 16:33 (3,250 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
New drum support, plate kit, top bearing seal & tripod kit (not pictured) and bottom seal ordered. Sadly, the counterface that fits on top of the support shaft is toast. Anyone know if replacements are available. |
Post# 825213 , Reply# 5   5/26/2015 at 07:35 (3,250 days old) by ServisChris (Southampton, Hampshire UK)   |   | |
You're certainly braver than me! I've stripped everything out of many washers and vacs and rebuilt them from scratch, but I wouldnt want to try a Hotpoint top loader. I had a 9605 that I gave to another collector, never had to work on it fortunatley
Hope the refurb works out well, I don't know much about the top loaders other than cosmetic information! Chris |
Post# 825277 , Reply# 6   5/26/2015 at 17:27 (3,249 days old) by sesteve (London, UK)   |   | |
hi Rob
Cracking on apace there. Hope you got the user manual ok. That is some corrosion which is mainly due to a build up of detergent so I guess it looks like this machine has done nothing but warm washes with non dissolving powder. I've attached a link to a new counter face and they also have the counter face mount. Keep us updated S :) CLICK HERE TO GO TO sesteve's LINK |
Post# 825423 , Reply# 7   5/27/2015 at 15:51 (3,248 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Does anyone know what oil the gearbox takes? Part number 151442? |
Post# 825806 , Reply# 8   5/30/2015 at 13:38 (3,246 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Does anyone know? |
Post# 825879 , Reply# 9   5/31/2015 at 02:50 (3,245 days old) by fido ()   |   | |
I would probably just bung in some SAE90 gear oil but you could ask on UKWhitegoods for a definitive answer. |
Post# 826680 , Reply# 11   6/5/2015 at 04:43 (3,240 days old) by sesteve (London, UK)   |   | |
hi Rob
Looking good - I need to spray the base of mine so thanks for the tip on the paint - will have to get some. I've had a quick look on-line using the following part numbers and some are showing as in stock - not sure which companies you have tried. C00146357, C00146336 and 151245 Give those ago and check in case it throws up results that you have not seen. S :) |
Post# 826710 , Reply# 12   6/5/2015 at 09:53 (3,240 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Thanks Steve - yup, I have googled those numbers already and have contacted the displayed companies - none of which have one :( |
Post# 826721 , Reply# 13   6/5/2015 at 12:44 (3,240 days old) by sesteve (London, UK)   |   | |
Bugger. I'll have a root about when I get back after the weekend amongst my spare bits in case I have one. I can't remember if I replaced the counter face in the machine I fixed the leak on. If I did then I would have kept the old one so if would be better than no counter seal. I'll drop you a message if I find it. S
Post# 827140 , Reply# 15   6/9/2015 at 05:39 (3,236 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Rob great restoration for the old washer, there is a repair guy we use in Norfolk who repairs Hotpoint top loaders, (he`s renovating my 1501 at the moment) and has a machine shop so can make new / old parts when required, his name is Mark Hill from Mark One domestics and his contact email is hillm2622@gmail.com
I re-sprayed my 1509 lid and back panel a few years ago, the paint match was Citroen Midnight Blue paint from Halfords, Looking forward to seeing yours all back together after the restore!! CLICK HERE TO GO TO chestermikeuk's LINK
Post# 827582 , Reply# 21   6/11/2015 at 13:15 (3,234 days old) by ooversanwashers ()   |   | |
Great work looks like its coming along nicely. Thanks :) |
Post# 827648 , Reply# 22   6/12/2015 at 06:10 (3,233 days old) by sesteve (London, UK)   |   | |
Hey Rob
Counterface on its way to you - hopefully you will get it tomorrow. You make this cabinet restoration look really easy but I'm sure if I had a go it would look terrible. I thought it looked really good with the etch primer so its going to look fantastic when you've finished it. I'll have to send you my Hoovermatic 3314L for you to work on when you are done. Its in a sorry state cosmetically and I haven't got round to sorting it out yet! S |
Post# 828069 , Reply# 25   6/15/2015 at 07:59 (3,230 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Filler primer rubbed down and cabinet sprayed with four coats of top-coat. R |
Post# 828090 , Reply# 26   6/15/2015 at 13:09 (3,230 days old) by triumphdolomite (Staffs(UK))   |   | |
That's looking good Rob, what paint have you used? Is it appliance white or an automotive paint. Triumph white 19? Ian |
Post# 828164 , Reply# 30   6/16/2015 at 04:46 (3,229 days old) by mjp2002 ()   |   | |
Could you not soak the heater element in vinegar or part fill the tub with vinegar and water and bring the water up to 85oC on programme 1 like you would descale a kettle? |
Post# 828191 , Reply# 31   6/16/2015 at 09:20 (3,229 days old) by sesteve (London, UK)   |   | |
Wow - the paint job looks great and the colour match is really good - it is a bluey grey colour so look forward to seeing the finished result. What kind of white paint is it?
Glad the counterface arrived. Its funny but the service manual covering the 1504 is more detailed than the later ones. It says in there to glue the bottom seal to the bowl support and to grease the inside of the drive nut as well as the gearbox outer tube. I have found that the sealing ring for the bellows seal is a real pain to deal with - there is no obvious way of ensuring that it is tight enough so hopefully the debor glue should help in your case. The other funny thing with my 1504 was that it was missing bits - water slinger, spring washer and cork washer. I have a suspicion that these were not used originally - the service manual does say of the cork washer - where fitted - but its not clear on the others! Perhaps they were design improvements. Good work on the dampers too. They have quite a grip so its good you managed to prise them open to get them glued in. Almost done now! S :) |
Post# 829204 , Reply# 35   6/23/2015 at 11:54 (3,222 days old) by sesteve (London, UK)   |   | |
Hey Rob
Glad you picked up the donor machine - and it great condition too - I would have the cabinet for my 9605 but its a bit far to collect for me so will have to sort out the scratch on it another way and yes please to the dampers. Is that a doily in the bottom of the outer tub amongst the limescale and goodness knows what else? Seems like there is a lot of gunk in that machine too. Could you see what was wrong with the gearbox on it as you stripped it down? The cabinet is looking good with the kick strip so will look really smart when it is finished. I've attached the 4 pages from the 1504 model so you can see the additional detail in case it helps. Cheers S |
Post# 829236 , Reply# 37   6/23/2015 at 16:35 (3,221 days old) by sesteve (London, UK)   |   | |
Hi Ian.
Did you have it from new as that would explain why it's in such good nick? I'm guessing the top oil seal must have failed for that to happen - it wasn't getting into the wash as well was it? There is a design flaw with all the top loader models. The well for the heater is a collection pit for all manner of fluff and other bits that go through the machine. It would have been better if the well had extended into the drain outlet as the heater is interlinked to the water level so should have been fine to drain out at the end. I'm dreading looking at my 1509 - I washed a couple of cheap sofa throws that I bought from Sainsburys when I moved in. The filter tray was totally clogged and there wasn't a lot left of the throws! The rest of it must be stuck round the heater. At least the limescale shows you were doing high temperature washes but you must have done lots of loads in it for that much and the doily may be fine after a wash in the machine rather than under it. Steve :) |
Post# 829292 , Reply# 39   6/24/2015 at 04:16 (3,221 days old) by sesteve (London, UK)   |   | |
Hi Rob
At what level was the water when it started leaking? If you fill the machine up gradually then it would point to which seal could be letting by. I've done a crappy drawing to show the 4 levels to check. 1. Looking at where it is leaking which appears to be the inside of the counterface I would say that the counterface mount and counterface should be ok - to prove you could fill up just so the bellows seal is covered. If it starts leaking then it is either of those or the joint between the face seal and the counterface. I'm not sure if there is a right and wrong way round to mount the face seal but it looks right from your pictures. It could be that the face seal is not sitting flat between the bowl support and the counterface either because the seal is distorted or the debor glue has not held it on level. 2. If that's ok and it doesn't leak, fill it up to the top of the bowl support just below the top of the bowl clamp. If it starts leaking here then it could be the o-ring in the bowl support. 3. If that's fine then fill further to below the top of the top seal 4. If that is ok fill to above the drive nut. If it leaks here then it could be the seal between the drive nut couterface and the top seal. Have you fitted the water slinger and o rings at the top of the shaft as shown in the drawings? These are not always included in the seal kits. Hopefully that will at least identify which point is weak. S |
Post# 829293 , Reply# 40   6/24/2015 at 04:19 (3,221 days old) by sesteve (London, UK)   |   | |
Hi Rob
At what level was the water when it started leaking. If you fill the machine up gradually then it would point to which seal could be letting by. I've done a crappy drawing to show the 4 levels to check. 1. Looking at where it is leaking which appears to be the inside of the counterface I would say that the counterface mount and counterface should be ok - to prove you could fill up just so the bellows seal is covered. If it starts leaking then it is either of those or the joint between the face seal and the counterface. I'm not sure if there is a right and wrong way round to mount the face seal but it looks right from your pictures. It could be that the face seal is not sitting flat between the bowl support and the counterface either because the seal is distorted or the debor glue has not held in on level. 2. If that's ok and it doesn't leak, fill it up to the top of the bowl support just below the top of the bowl clamp. If it starts leaking here then it could be the o-ring in the bowl support. 3. If that's fine then fill further to below the top of the top seal 4. If that is ok fill to above the drive nut. If it leaks here then it could be the seal between the drive nut couterface and the top seal. Have you fitted the water slinger and o rings at the top of the shaft as shown in the drawings? These are not always included in the seal kits. Hopefully that will at least identify which point is weak. S |
Post# 829297 , Reply# 42   6/24/2015 at 04:43 (3,221 days old) by sesteve (London, UK)   |   | |
I know how frustrating these things can be so happy to try and help. So it is either the o-ring, the face seal where it meets the bowl support or the face seal where it meets the counterface. Hmmm! What was the face seal like from the donor machine? is it worth trying that to see if that solves it? If so then you could get a new one. If not then the o ring could be changed. Is the bowl support a nice tight fit on the shaft? It might be better not to put the debor or sealant on this. Just checking that you raised the gearbox before you tightened the bowl support - don't want to accuse you of sucking eggs but that will help push the seals tightly together?
I'm not sure if it is worth putting the machine on to see if a bit of action allows things to bed in. I'm sure when I did my first seal on one of these I had similar issues but once it had done a cycle it seemed to solve itself and has been fine since. S |
Post# 829514 , Reply# 48   6/25/2015 at 11:02 (3,220 days old) by sesteve (London, UK)   |   | |
Well done Rob
At least you know what it is so hopefully a new seal will solve it permanently. Console looks great too. What are the machines behind the 1509? I don't recognise the valve configuration of the one on the right. Ian - dolomite carpets sounds like a challenge for the toploader! Did it do the trick? I tried washing feather pillows once over - never again!! S |
Post# 829556 , Reply# 50   6/25/2015 at 16:47 (3,219 days old) by matchboxpaul (U.K)   |   | |
Hi Rob. Always nice to see a restoration job come back together. Must be one of the most thorough overhaul jobs conducted on one of these for many a year. Keep on posting the updates! Regards Paul |
Post# 831220 , Reply# 53   7/7/2015 at 14:23 (3,208 days old) by matchboxpaul (U.K)   |   | |
Cannot wait for the grand unveil. Wonderful machines the 1509's, with the /10 being the pinnacle and great that you were able to save one. Paul |
Post# 831250 , Reply# 54   7/7/2015 at 16:49 (3,207 days old) by triumphdolomite (Staffs(UK))   |   | |
Rob Glad that you've managed to stop the dripping and it seems to be performing better. The clutch shoes shouldn't be too worn as I changed them two or three years before I took it out of service. Ian |
Post# 831357 , Reply# 55   7/8/2015 at 08:57 (3,207 days old) by sesteve (London, UK)   |   | |
Hi Rob
Glad its all back together and look forward to seeing the final result. The position of those microswitches makes them very vulnerable to breaking - I broke my one so stole one off the 9605 - must remember to sort that out! I'm guessing the seal has bedded in which has stopped the leaks. I ran my 1504 this weekend after overhauling it and no leaks at all with a 42 year old seal so I was really surprised. Have you stuck the soundproofing material to all of the inside of the cabinet. I was considering sticking felt underlay to the outer tub of one of my machines to improve its energy use and speed up the heating process for hot washes so will be interesting to see if you notice a difference. So I'm guessing you will be allowed to keep this in the house now if its going in your utility room! With all the hard work you've put into it it deserves to be pride of place. Cheers S :) |
Post# 833437 , Reply# 59   7/23/2015 at 14:58 (3,192 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 833556 , Reply# 60   7/24/2015 at 09:36 (3,191 days old) by sesteve (London, UK)   |   | |
Well done again. As they say perseverance pays off - apparently and you have certainly persevered with this one.
I'm a bit surprised that it is noisy on the wash as generally the noisiest part is the draining but having said that they all sound slightly different to each other. The noise on my 1509 lessoned quite a bit once I'd sorted out the clutch shoes as one of them had jammed in position and now it makes the same amount of noise for wash and spin. Is the leak coming from the dreaded support tube? I think that the debor glue that you used to put the counterface in may be causing the problem as it looks from the photos like it could interfere with the movement of the face seal and allow the seals to part when they are moving. Could be worth clearing that out and seeing if that works. Otherwise I think I'm out of suggestions. Hope you get it sorted S :) |
Post# 833999 , Reply# 62   7/27/2015 at 04:14 (3,188 days old) by electron1100 (England)   |   | |
This has been a great thread about a great machine, I still think these are the best machines Hotpoint ever produced.
I too had a few problems with leaks on mine but not to the extent you had with faulty seals, fortunately mine worked but I had a leak after everything else occur on one of the thermostat seals,oh and one of the thermostats stopped working! I remember water testing it just as you did, and the exasperation I felt when there was a drip GRRRRR.....ha ha :-) But once I had sorted that and everything else what a great machine to use. I am so pleased you stuck it out and got the beauty up and running |
Post# 834662 , Reply# 64   7/31/2015 at 16:10 (3,183 days old) by triumphdolomite (Staffs(UK))   |   | |
Rob Congratulations on finally getting everything watertight. Ian |
Post# 835171 , Reply# 66   8/5/2015 at 10:04 (3,179 days old) by sesteve (London, UK)   |   | |
Well done Rob
Glad you have finally cracked it and I know what you mean about not tempting fate with the back panel but hopefully it can go back on now! Seems like the old seals are better than the new! Despite being a water guzzler, the quick wash times are a real bonus and the spin is pretty thorough too. I sometimes put mine on late in the evening and use the rinse hold until the morning so I can peg out before I head to work - now that's a test for the seals! S |
Post# 835173 , Reply# 67   8/5/2015 at 10:15 (3,179 days old) by keymatic (London / UK)   |   | |
Hi Rob,
Just a quick question regarding your 9605, with the "Rinse Hold" does it agitate for long after releasing the button ? My aunt had one and my mum had a 1509 but i can't remember the sequence. I have managed to get hold of a brand new 9605W as a back up for my 1504. Cheers Keith
Post# 835229 , Reply# 70   8/5/2015 at 16:26 (3,178 days old) by sesteve (London, UK)   |   | |
Hi Rob
Those parts would be great if you don't mind. Let me know if you want something for postage. I think I gave you my address in one of the emails I sent previously. Hi Keith. Well done on getting the 9605. Hopefully you won't need it as a backup as the 1504 will keep on going for a long time yet but it's a great backup machine to have. The main difference is the brake being applied after the spins so no coasting which I thought was a bit harsh and also the first agitated rinse along with the brittle console covers of course. I've got a service manual I can send you if you want - it tells you how to disable the agitated fill sequence if this machine has it. I just checked the manual for the 1509 and the rinse hold kicks in as soon as the machine is full and will agitate for 3 impulses at 40 seconds each so you are right Al 2 mins as well |
Post# 835308 , Reply# 71   8/6/2015 at 03:11 (3,178 days old) by keymatic (London / UK)   |   | |
Hi Rob, thanks for confirming that..it will make life easier if i do decide to use it as currently I have to be around to add the fabric conditioner on the 1504, not really a problem and i have been doing it for over 10yrs now but would be nice to leave the machine with the Rinse Hold option.
It was such a steal at £150 for a brand new 9605 - i think towards the end of manufacturing they were selling for around the £500. Many thanks for the info Cheers Keith
Post# 835575 , Reply# 72   8/7/2015 at 13:46 (3,177 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Blimey Keith - yes, £150 is a bargain for a new vertical-type top loader. My renovated 1509 owes me not much less than that... Steve - I am having a "workshop day" tomorrow, so will try and get together those bits for you - nothing due for the postage - just take it as a big thanks for all your help. R |
Post# 835580 , Reply# 73   8/7/2015 at 15:04 (3,177 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 836046 , Reply# 74   8/11/2015 at 02:35 (3,173 days old) by triumphtoledo (Shropshire/Worcestershire)   |   | |
Yes, the machine recirculates water into the lint tray at the top but it does not utilises a separate pump. Instead, the drain pump rotates in the opposite direction. The drain pump is mechanical and is driven by the main motor by a separate flexible drive (i.e. a piece of canvass!) R |
Post# 836053 , Reply# 75   8/11/2015 at 05:09 (3,173 days old) by keymatic (London / UK)   |   | |
Hi Rob,
Yep it was a steal at £150 !! - I think the 1504 has done it's time, what with being in use for well over 10yrs now and never going wrong, plus being over 44 years old. One question i would throw out to all is can the lid-latch be permanently disengaged ? I know on my aunt's machine i could only open the lid about an inch before the action stopped. On my 1504 it was easy to disable the safety mechanism as it was purely a micro switch, however on the new machine i think its a bit more complicated. As the machine is way outside my collecting timeframe im not over sure on all the technical stuff. Many Thanks Keith |
Post# 836086 , Reply# 76   8/11/2015 at 09:09 (3,173 days old) by sesteve (London, UK)   |   | |
Hi Keith
I've attached some info on the lid interlock. The microswitch is located in the lid latch assembly and I guess if you override the microswitch you can use the machine with the lid open as the rest of the interlock is to stop you opening the lid when the gearbox is rotating. What did you do on your 1504 as is really difficult to defeat it physically whereas the 9506 you just need to stick something in the hole for the lid peg. S |
