Thread Number: 59850
/ Tag: Ranges, Stoves, Ovens
Late-60s (I think) Westinghouse Wall Oven |
Post# 825133 , Reply# 1   5/25/2015 at 19:16 (3,230 days old) by xraytech (Rural southwest Pennsylvania )   |   | |
Post# 825138 , Reply# 2   5/25/2015 at 19:41 (3,230 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Yep, side opening. GREAT idea. Wise someone, who made appliances that mere mortals could afford, would pick up the idea. |
Post# 825228 , Reply# 6   5/26/2015 at 11:38 (3,229 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
Post# 825239 , Reply# 7   5/26/2015 at 12:39 (3,229 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Can you even open the doors enough to remove the shelves with the door knob where it is? |
Post# 825290 , Reply# 8   5/26/2015 at 18:48 (3,229 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Models: OAC21S with Rotisserie OAC21G with Roast Guard OAC21R with Rotisserie & Roast Guard These were the model numbers in 1965 so there might be letter changes to reflect different years. |
Post# 825311 , Reply# 9   5/26/2015 at 22:04 (3,229 days old) by norgeway (mocksville n c )   |   | |
Had the single oven model, 1966 ,was still in the house when she died and the house was sold a few years ago, Westinghouse was still making quality then. |
Post# 825320 , Reply# 10   5/26/2015 at 23:34 (3,229 days old) by PhilR (Quebec Canada)   |   | |
Tom, I was wondering the same when I saw the picture! I guess in the worst case, you can open the door before you open the oven's door! As long as the entrance door isn't the kind that closes by itself (which is often required in large buildings).
If it would have been a regular bottom-hinged door, it would probably have been worse and might have required to fully open the entrance door before opening the upper oven's door! |
Post# 825347 , Reply# 11   5/27/2015 at 06:48 (3,228 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The brochure says the oven could be installed with the doors opening in either direction. Perhaps they can be changed. |
Post# 825675 , Reply# 15   5/29/2015 at 16:09 (3,226 days old) by CircleW (NE Cincinnati OH area)   |   | |
They should have used a 3" filler to the right of the oven cabinet, so the oven door would clear the doorknob. |
