Thread Number: 60931
Whirlpool duet - New sound |
Post# 835442 , Reply# 1   8/6/2015 at 19:16 (3,179 days old) by kb0nes (Burnsville, MN)   |   | |
Didn't you just buy this machine about a month ago? Its not bearings or a spider in a month... Keep running it and keep an ear on it. I'd bet something in the suspension was making a little noise. Having it happen once isn't a problem, keep using it and if it continues then you may need to call for warranty service eventually.
Its easy to get paranoid when you start searching the Interwebs for a problem like this. Every time I look at WebMD I'm sure I have a terminal disease! lol |
Post# 835480 , Reply# 3   8/6/2015 at 23:21 (3,179 days old) by Mattl (Flushing, MI)   |   | |
Well if it's less than a year, it should be under warranty, at least here in the States we have a 1 year warranty. Not sure about what is offered in Canada. I would certainly want it on record there was a potential problem befroe the time ran out. |
Post# 835504 , Reply# 4   8/7/2015 at 05:29 (3,179 days old) by mark_wpduet (Lexington KY)   |   | |
my OLD duet was squeaking on and off as the drum rotated one way using Sanitary....but then it stopped squeaking for months, then it started again (it wasn't a horrible squeak, but you could hear it. It stopped again on its own. I haven't heard it since. This was like 3 years ago or so....I never heard any clicks though as I turned the drum.
Post# 835560 , Reply# 5   8/7/2015 at 12:26 (3,178 days old) by washerdude (Canada )   |   | |
Thats a little ironic. Because it was on the Eco Sanitize with oxi cycle when it did this. |
Post# 835732 , Reply# 6   8/8/2015 at 21:29 (3,177 days old) by washerdude (Canada )   |   | |
It did it again. The sound seems like its coming from the back of the unit towards the tub assemebly. Next time we do a load I'm going to be ready to film it. |
Post# 835738 , Reply# 7   8/8/2015 at 22:25 (3,177 days old) by washerdude (Canada )   |   | |
I should also state that during the vibration test while spinning empty at full speed (1200RPM) it did not make this noise when it finished the drain and spin cycle. |
Post# 835751 , Reply# 8   8/9/2015 at 01:15 (3,177 days old) by A440 ()   |   | |
Is it like a whistling sound? Like if you made a whistling sound through your teeth but just fainter? And it mostly happens on the slower tumble of the rinse? B |
Post# 835758 , Reply# 9   8/9/2015 at 03:07 (3,177 days old) by mark_wpduet (Lexington KY)   |   | |
the chirp of a bird when the drum would rotate (like a quick chirp). Never during a spin, but just during tumbling and I believe it was just ONE way, not both ways. I heard it a few times during sanitary, but not during the entire cycle, and I think I also heard it in another cycle during one of the rinses. But I haven't heard it in a long time now, so whatever it was, it went away...
Post# 836492 , Reply# 12   8/13/2015 at 19:28 (3,172 days old) by appnut (TX)   |   | |
