Thread Number: 61133
/ Tag: Wringer Washers
Hotpoint empress wringer washer. Dimensions needed |
Post# 837749   8/22/2015 at 10:42 (3,168 days old) by Ricky5050 (Durham Britain)   |   | |
Hi guys do any of you have a hotpoint empress wringer washer you can measure the dimensions for me?
I'm thinking about getting an old beat up one that's beyond repair and using the casing to hide an integrated modern fl washer in side. I'm thinking one might fit and I'd use the front as a door so it looks old but is modern Does anyone have an old beat up machine ? Or a vintage front loader from the 1950s 1960s that doesn't work but has a good casing ? Any help would be great Thanks Richard |
Post# 837752 , Reply# 1   8/22/2015 at 12:09 (3,168 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Richard
It might be better if you looked for a Sevis Superheat machine as the front already opens up - see the link. I am not suggesting this one, just so you can see what I am talking about. It looks like the Empress might not quite be big enough, see below. Might be worth checking out an H axis machine though. Or failing all else, what about a SMEG washer? More problems with the Bendix? Al CLICK HERE TO GO TO vacbear58's LINK on eBay
Post# 837826 , Reply# 2   8/23/2015 at 04:49 (3,168 days old) by Ricky5050 (Durham Britain)   |   | |
Hello Al.
Yes the heater on the bendix is now either on all the time or off. I could hard wire it to plug separate but seems a faff I was thinking about an integrated w/d in a empress case but I think your right it's too big. Never thought of a Smeg . Just checked also email off washer man in lancs he only had the incoming water thermostat that mixes hot n cold as fills not heater thermostat. So no further forward there. This sunny weathers made me tho if you and Mike and the washer heaven how it going ? I've been tinkering with my keymatic may have got the spin clutch sorted. ! Ordered some glycerin to massage the hoses. A few new spade connectors and it might just do a wash ! Hope to see you all doon Richard |
Post# 837961 , Reply# 4   8/24/2015 at 04:35 (3,167 days old) by Ricky5050 (Durham Britain)   |   | |
I've just ordered these although they've not arrived yet, they're from eBay I'll let you know
Cheers
