Thread Number: 63428
I got a Filter-flo doday! and now this.... |
Post# 860083   1/4/2016 at 19:35 (3,005 days old) by mopar65 (Almont MI)   |   | |
Post# 860092 , Reply# 1   1/4/2016 at 20:07 (3,005 days old) by bajaespuma (Connecticut)   |   | |
Post# 860096 , Reply# 2   1/4/2016 at 20:21 (3,005 days old) by joelippard (Hickory)   |   | |
Post# 860104 , Reply# 3   1/4/2016 at 20:30 (3,005 days old) by mopar65 (Almont MI)   |   | |
Post# 860118 , Reply# 4   1/4/2016 at 21:16 (3,005 days old) by Yogitunes (New Jersey)   |   | |
that bit of a drag sound I would not worry about.....many make it, and many do not...
my opinion, if it ain't broke, don't fix it..... it locks the tub and agitates, it releases and spins smoothly, and it stops on a dime as designed, I would leave it alone.....until something seriously happens... I have one that 'knocks' 4 times when the spin is over.....and I have a spare to install once it finally stops working, but as long as it does what its supposed to....leaving well enough alone.... but if you insist, you might have better luck finding a whole tranny than the individual parts.....but still may take some searching |
Post# 860127 , Reply# 5   1/4/2016 at 21:42 (3,005 days old) by mopar65 (Almont MI)   |   | |
Post# 860133 , Reply# 6   1/4/2016 at 22:15 (3,005 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 860149 , Reply# 8   1/4/2016 at 23:24 (3,005 days old) by delaneymeegan (Midwest)   |   | |
Post# 860150 , Reply# 9   1/4/2016 at 23:25 (3,005 days old) by roto204 (Tucson, AZ)   |   | |
Post# 860183 , Reply# 11   1/5/2016 at 05:50 (3,005 days old) by joeypete (Concord, NH)   |   | |
Mine makes the kabang noise when it stops but that's normal. The last little wind down noise mine does not make but it doesn't sound serious. My machine makes all kinds of rattles and such. Drives me crazy really. I need to pull it out again and tilt it on it's back so i can get to everything and put some tape on the suspension to quiet it down.
Post# 860203 , Reply# 12   1/5/2016 at 08:51 (3,005 days old) by whitetub (Montreal, Canada)   |   | |
Our Hotpoint filter Flo, that we had in the 1980's, was actually much louder than this. And it was like that from day one. Brand new. That's how they are built. |
Post# 860209 , Reply# 13   1/5/2016 at 09:42 (3,005 days old) by glomain (tuscarawas cnty. (eastern ohio))   |   | |
Post# 860214 , Reply# 14   1/5/2016 at 10:39 (3,005 days old) by brucelucenta ()   |   | |
Yep, that's what my mom & dad's GE did from the day they bought it back in '64. |
Post# 860215 , Reply# 15   1/5/2016 at 10:46 (3,005 days old) by alr2903 (TN)   |   | |
IIRC, after the next fill no matter wash/rinse the tub indexes a bit, you hear one bang when it locks and stops the index. This too is a normal/usual sound. |
Post# 860232 , Reply# 16   1/5/2016 at 13:13 (3,005 days old) by mopar65 (Almont MI)   |   | |
I just put a full load in and on braking it was way werse. I pulled the basket out and you can see were it had been hitting the outer tub from over loading/out of balanced loads. I think I'm going to give it a few days and see if it gets any better as I'm positive it has been sitting for a long time.
Post# 860233 , Reply# 17   1/5/2016 at 13:15 (3,005 days old) by mopar65 (Almont MI)   |   | |
Post# 860246 , Reply# 18   1/5/2016 at 14:44 (3,005 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 860256 , Reply# 19   1/5/2016 at 15:34 (3,005 days old) by ken (NYS)   |   | |
Post# 860294 , Reply# 20   1/5/2016 at 18:53 (3,004 days old) by mopar65 (Almont MI)   |   | |
Post# 860296 , Reply# 21   1/5/2016 at 18:59 (3,004 days old) by delaneymeegan (Midwest)   |   | |
Yes, the wear marks with rust on the inside tub is normal, as well.
Whenever you have a stationary outer tub, and an inner tub that can literally bang into that porcelain tub, ..... without the benefit of at least a cushioned bumper, you know you have a design flaw. And GE made these for 30 years. Notice too: fill that tub with the water level set on high, open that top and take a look at the large volume of water on the OUTSIDE of the wash tub. That's why these are called water hogs. and again, GE made these for 30 years. They sure are fun though. The first washer I got back in 1983, was a trade-in 1970 avocado sudsaver GE with 4 toggle switches on the control panel, and a lit timer dial. It had a sock stuck in the pump. Oh, notice the drain connection from the tub to the pump. Is there any grill on that tube? Nope. A sump under the tub to collect large things that could damage the pump? Nope. Any type of device, anywhere, to protect the pump from getting damaged by large items? Nope, Nada, none. Drop a 3" nail in the outer tub and you're screwed. If your washer is in generally good condition, as it looks to be, it will have a filter flo smell, as well. I don't know how to explain it. I think its the combination of traditional Tide, Downy, and rubber mixed together. I love it. If they made an air freshner labeled 'traditional GE filter-flo', I'd buy it. I recently acquired an Almond 1982 GE with 3 push button instead of toggles. I opened the lid and smiled. It has 'the smell'. lol Consider yourself lucky to have a filter-flo vs. a rim-flo. With the rim-flo, as was found on JCPenny and Hotpoint washers, the lint accumulated in the rim mounted lint filter and was supposed to awkwardly spin off, fall into the bottom of the machine, and somehow magically make it's way to the drain and be expelled. But that's not how it worked. What usually happened is the lint would get spun off the rim filter but it stuck to the outer tub wall, and there it accumulated. Sometimes, as it decayed it would slowly slide down the tub, and between wash loads, dry and form masses on the bottom of the tub. Emm, yeah. Smell THAT. The smell of traditional GE filter-flo but with the tinge of wet dirty lint balls molding on the outer tub wall. Nah, we don't need to bottle that one. |
Post# 860298 , Reply# 22   1/5/2016 at 19:01 (3,004 days old) by delaneymeegan (Midwest)   |   | |
Post# 860300 , Reply# 23   1/5/2016 at 19:10 (3,004 days old) by mopar65 (Almont MI)   |   | |
Post# 860301 , Reply# 24   1/5/2016 at 19:16 (3,004 days old) by mopar65 (Almont MI)   |   | |
Post# 860307 , Reply# 25   1/5/2016 at 19:37 (3,004 days old) by delaneymeegan (Midwest)   |   | |
Very nice. I love the toggles on the dryer.
Yours is mid to late 80s. Large capacity washer and standard capacity dryer. As far as the smell. Don't bother. Like a ghost of wash loads past, it will haunt your washer for ever. It's a good ghost. Think Casper. You shouldn't have lint build up, though. My recent GE. Standard capacity. Needs cleaning. similar console but older. |
Post# 860309 , Reply# 26   1/5/2016 at 19:47 (3,004 days old) by mopar65 (Almont MI)   |   | |
Post# 860379 , Reply# 27   1/6/2016 at 05:59 (3,004 days old) by joeypete (Concord, NH)   |   | |
Yours is the Extra Large capacity without mini basket. It has the same cycles as mine does...though mine is just Large capacity. The Extra Large is good...Large is just a wee bit too small sometimes. I've had to split some of my laundry loads, wouldn't have to if I had the Extra Large. But I was lucky to find my set so I won't complain :)
Post# 861276 , Reply# 28   1/11/2016 at 19:33 (2,998 days old) by mopar65 (Almont MI)   |   | |
Post# 861291 , Reply# 29   1/11/2016 at 20:35 (2,998 days old) by washerlover (The Big Island, Hawai’i)   |   | |
