Thread Number: 63564
LG F1479FDS5 not heating...or is it? |
Post# 861659 , Reply# 1   1/13/2016 at 16:49 (3,023 days old) by dyson2drums (United Kingdom)   |   | |
Hi
I have the same model and mine's 5 years old now. I've not had any trouble with heating. I know if you select a standard wash or a time save wash it will heat to 5 degrees less give or take a few degrees. If you select intensive it heats to temperature or there abouts. Also I would recommend that you use the Tub clean cycle by holding in the temp and rinse button in together until the display states tub clean. I usually add a finish dishwasher tablet in the drum or add washing machine cleaner and set it going. It spins at higher rpm so the cleaner can get to areas normal tumbling can't reach. We get through 1 or 2 loads daily and have no issues with mould what so ever. I'd advise you leave the door open when not in use and also leave the detergent draw open when not in use to let it air out. See how it goes and message me if you have any questions |
Post# 861767 , Reply# 3   1/14/2016 at 07:09 (3,023 days old) by dyson2drums (United Kingdom)   |   | |
