Thread Number: 63844
W Laundromat test run! |
Post# 864206   1/26/2016 at 20:04 (3,011 days old) by moparwash (Pittsburgh,PA )   |   | |
Brought it home December 26th and one month later on January 26th, its ready for its test run! The drain hose I got was a universal one that cant be tightened enough and one of the fill hoses I got has a clog in it! (back to the store tomorrow) Used a Y adapter at the faucet to run all-hot water. It fills up, but the timer does not seem to be moving as it washes far longer than what the cycle times listed on the inside of the door. The pump works, though the solenoid is loud as expected and it spins, though the spin solenoid sounded like it got stuck. Tomorrow Ill get new hoses and check all the other ones again for more tests!
Post# 864211 , Reply# 1   1/26/2016 at 20:44 (3,011 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Inside of tub on pix 1 looks like iron water settled. My neighbor had a much newer Laundromat given to them years ago and had the same issue. Iron out on low level, hot fill stop and go in there with a non abrasive scrubbie cleared the tub up and it worked like a charm, never stained anything until it finally died last year when rust finally killed everything.
Post# 864230 , Reply# 2   1/26/2016 at 22:45 (3,011 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 864233 , Reply# 3   1/26/2016 at 23:13 (3,011 days old) by norgeway (mocksville n c )   |   | |
To have a Westinghouse front loader in my house one of these days! |
Post# 864261 , Reply# 4   1/27/2016 at 07:50 (3,011 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
I had a Maytag several years ago that had the tub stained with Iron. Went to Ace Hardware and got some "Iron Out" and it cleaned it right up. That is one beautiful machine. They are great washers - I have a "Space-Mate" and use it every week. Bob |
Post# 864263 , Reply# 5   1/27/2016 at 07:54 (3,011 days old) by turquoisedude (.)   |   | |
Post# 864267 , Reply# 6   1/27/2016 at 08:14 (3,011 days old) by glomain (tuscarawas cnty. (eastern ohio))   |   | |
Post# 864287 , Reply# 7   1/27/2016 at 10:40 (3,011 days old) by Yogitunes (New Jersey)   |   | |
Post# 864397 , Reply# 8   1/27/2016 at 20:18 (3,010 days old) by norgeway (mocksville n c )   |   | |
Westinghouse and Bendix frontloaders wash rings around any of the new frontloaders! |
Post# 864402 , Reply# 9   1/27/2016 at 20:31 (3,010 days old) by moparwash (Pittsburgh,PA )   |   | |
The timer advances through the cycles and there is a leak in the hose from the tub to the pump...have to put goop on that. I have to figure out why the boot is twisted, the way it is now it directs the water to the door and it drips out of the bottom of the door. The rust stains will be cleaned and soon it will be ready for its first load. Thanks to everyone for your kind comments and help for getting this far!
Post# 864470 , Reply# 10   1/28/2016 at 09:05 (3,010 days old) by glomain (tuscarawas cnty. (eastern ohio))   |   | |
Post# 864519 , Reply# 11   1/28/2016 at 15:47 (3,010 days old) by christfr (st louis mo)   |   | |
Post# 864607 , Reply# 12   1/29/2016 at 06:14 (3,009 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 864907 , Reply# 13   1/31/2016 at 10:20 (3,007 days old) by moparwash (Pittsburgh,PA )   |   | |
Primed and Painted underneath...still have to get the right glop to fix the leak in the tub to pump hose and scrub the iron stains out of the tub...(Scrub Christina Scrub!!)....lubed the drive pulley area with lithium....really quiet now!
