Thread Number: 63886
/ Tag: Wringer Washers
Maytag El2 |
Post# 864583 , Reply# 1   1/28/2016 at 23:13 (3,009 days old) by bradross (New Westminster, BC., Canada)   |   | |
Hello Fred and welcome to the forum!
Perhaps it was just a typo but I thought I would offer a correction on the model number. And just for some background on Maytag's system ... E - unique style 2 - built after second world war L - electric (or M - gasoline "Multi-motor") P - equipped with discharge pump S - equipped with wringer safety system To answer your question - the bar on the top controls the pressure on the wringer rolls. I've attached 3 pages from a vintage instruction manual (you can still find these frequently on ebay). Of particular note is proper care of the rolls when not in use - they should be locked apart so as to avoid creating flat spots. Hope this information will be of good use to you! Enjoy using your "new" Maytag - they're fantastic old machines! I've got 3 - two model 30s from 1935 and one model E2LP from 1977. |
Post# 864585 , Reply# 2   1/28/2016 at 23:31 (3,008 days old) by Stan (Napa CA)   |   | |
Someone here with a decoder may come by, and can identify the year and month of manufacture of your machine.
At a glance.. Il take a guess that it's a 1966. The black agitator may be a replacement from a older machine. If it is a 1966 model...it would have come with a aqua colored agitator (same color as your release bar) The T bar on top of the wringer.. I think you referring to the tension bar. Maximum tension is used when fabric is being run through the wringer. When finished the release bar is used to release tension and to separate rollers so their not touching during times when the machine is not in use. This is done in order to avoid getting flat spots on the rollers. I can't tell from the pic if your machine is a pump model or not. Feel free to ask more questions. If you have never used a wringer, you'll need us! LOL Hope this helps |
