Thread Number: 63977
/ Tag: Wringer Washers
E2L wringer issues |
Post# 865528 , Reply# 1   2/4/2016 at 16:07 (2,975 days old) by bradross (New Westminster, BC., Canada)   |   | |
The wringer cap is connected to the spring tension, therefore it is designed to separate from the lower housing somewhat to allow for thick articles.
First - are you starting the item centered in the middle of the wringer? If not, that would be the correct procedure to ensure even pressure on the article. Second - there is a possibility that the spring tension is tighter on one side than the other. This could cause the cap to raise on one side more readily than the other. |
Post# 865534 , Reply# 2   2/4/2016 at 16:27 (2,975 days old) by nigelman ()   |   | |
Where is the spring tensioner? I have a manual on order. Not seeing anything like a spring tensioner. Is there a schematic available? |
Post# 865578 , Reply# 3   2/4/2016 at 21:39 (2,975 days old) by bradross (New Westminster, BC., Canada)   |   | |
I learned that the tension springs cannot be adjusted to increase tension. You will find those if you reach up under the wringer housing - or you'll see them clearly if you remove the entire wringer assembly. There are nuts that secure the tension springs, but the manual states that tightening them will actually NOT increase tension. I had mistakenly thought they would respond the same as the tension springs and nuts in the earlier models A/30/32.
So ... back to the other possibility. Are you placing the wet articles centered through the wringer, in a uniform width and thickness, as directed in Page 9 (attached)? There is a definite technique to proper wringing. Wish I was there to give you an "in person" demo!
Post# 865644 , Reply# 4   2/5/2016 at 08:27 (2,974 days old) by alr2903 (TN)   |   | |
Brad that is a beautiful Gray Ghost on your avatar. A |
