Thread Number: 63993
W Laundromat Video! |
Post# 865698   2/5/2016 at 17:00 (2,974 days old) by moparwash (Pittsburgh,PA )   |   | |
A video at last!...I should of held the phone sideways for a wider shot, but here it is!..the motor drips a little from the end with the pulleys on it (its been refreshed by the electric place) and the water valve does not shut off (have to check the water selector switch and water valve wiring) and get a hose for the bleach dispenser and put the bleach level light bulb back in..Other than that its nice and quiet!
CLICK HERE TO GO TO moparwash's LINK This post was last edited 02/05/2016 at 18:02 |
Post# 865770 , Reply# 1   2/6/2016 at 05:56 (2,974 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 865775 , Reply# 2   2/6/2016 at 06:49 (2,974 days old) by sarjam ()   |   | |
Looks great |
Post# 865780 , Reply# 3   2/6/2016 at 07:45 (2,974 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 865789 , Reply# 4   2/6/2016 at 08:43 (2,974 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 865797 , Reply# 5   2/6/2016 at 09:43 (2,974 days old) by alr2903 (TN)   |   | |
Jerry very nice work. I think you may have posted the first video of a "Potato Pulley", in action. I did not realize their diameter. You have a beautiful Laundromat. Arthur |
Post# 865804 , Reply# 6   2/6/2016 at 10:34 (2,973 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 865805 , Reply# 7   2/6/2016 at 10:47 (2,973 days old) by A440 ()   |   | |
Such a great looking washer.
Post# 865844 , Reply# 8   2/6/2016 at 17:46 (2,973 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 865855 , Reply# 9   2/6/2016 at 18:58 (2,973 days old) by moparwash (Pittsburgh,PA )   |   | |
Today's video...the bleach dispenser light bulb has been added...the water valve does not shut off...it will let the tub fill with water even when the machine is not running
CLICK HERE TO GO TO moparwash's LINK |
Post# 865902 , Reply# 10   2/6/2016 at 23:55 (2,973 days old) by A440 ()   |   | |
I had no idea this model stopped when the door was opened. Very cool.
Post# 865933 , Reply# 11   2/7/2016 at 08:01 (2,973 days old) by mayken4now (Panama City, Florida)   |   | |
Jerry, I am with Brent on the door opening stopping the machine. I had a WCI Laundromat back in the 80's and it did not stop when the door was opened while in operation, or not that my ole brain can remember anyway. Yep very cool machine, and looks like you may have had some rest before posting this one. |
Post# 865948 , Reply# 12   2/7/2016 at 09:35 (2,973 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Great to see the progress on your washer.
Water not shutting off, if it shuts off when you unplug the washer the inlet valve is working fine, then try taking the air-dome hose off at the pump and try blowing in to it and see if the water shuts off, if not the water level switch is either bad or miss-wired.
It was fun seeing this washer last weekend, let me know what you find out about the water shut off problem.
Post# 865967 , Reply# 13   2/7/2016 at 11:22 (2,972 days old) by hippiedoll ( arizona )   |   | |
Your restoration progress in coming along smoothly! That is a BEAUTIFUL front loader you have there. And of course, me LOVES lights. And the glowing illumination from the bleach dispenser looks awesome!
Windows & lights, my 2 favorite combinations on appliances! You got a GREAT looking machine there Moparwash!! :o) |
Post# 865980 , Reply# 14   2/7/2016 at 14:32 (2,972 days old) by moparwash (Pittsburgh,PA )   |   | |
Glad you like it, Hippiedoll!
John - This is what happens with the water valve Machine Off - Faucet on = No fill Machine On - Faucet on = Fill Door Open - Facuet on = Fill Shut Machine Off - Faucet on = Fill I have to try the hose from the pump to the water level switch...I don't want to break another nipple off the air dome/pump cover again so Ill have to be real careful or just hook up another hose at the water level switch..Im trying to lube the scraping noise in the video with lithium grease where the pulley goes up and down and has a nylon part in the pulley glide... Ill check the wiring again on that switch. Thanks again for stopping by to check it out! This post was last edited 02/07/2016 at 17:37 |
Post# 866017 , Reply# 15   2/7/2016 at 18:41 (2,972 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 866020 , Reply# 16   2/7/2016 at 18:49 (2,972 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 866289 , Reply# 17   2/9/2016 at 03:04 (2,971 days old) by alr2903 (TN)   |   | |
Jerry, I thought you might like this if you don't already have one. CLICK HERE TO GO TO alr2903's LINK on eBay |
Post# 866703 , Reply# 18   2/11/2016 at 18:30 (2,968 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 866708 , Reply# 19   2/11/2016 at 19:05 (2,968 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
I wouldn't worry about that fill valve, Jerry. My old Maytag leaks into the tub, but it is as simple as shutting water off to it when its not in use. Which everyone should do anyways. I was a BPI Energy Auditor before retiring and I have seen so much damage done to a home, just from a burst washer hose that nobody expected because someone was too lazy to shut the water off to it when they were done.
Post# 866718 , Reply# 21   2/11/2016 at 19:50 (2,968 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 866722 , Reply# 22   2/11/2016 at 20:33 (2,968 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 866764 , Reply# 23   2/12/2016 at 07:20 (2,968 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 866840 , Reply# 24   2/12/2016 at 16:18 (2,967 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I would like to see a full cycle when you get the machine fully restored. |
Post# 866996 , Reply# 25   2/13/2016 at 13:51 (2,966 days old) by moparwash (Pittsburgh,PA )   |   | |
Here are the results from today's test:
Faucet on, Machine off = Fill Faucet on, Machine on = Fill Let tub fill to bottom of door opening, disconnect air dome hose from pump, blow into it, the water level switch it is attached to makes a click sound, but water still enters the tub Unplug machine = Still fills. I checked the wires on the water level switch behind the door and they are hooked up the right way, and checked the water valve wires against the wiring diagram and they are hooked up like so. Ill retry the test tomorrow to see if anything changes and I cleaned out the bleach dispenser today |
