Thread Number: 64443
Maytag A612 No Spray Rinse during Slow Spin |
Post# 870988 , Reply# 2   3/7/2016 at 10:04 (2,943 days old) by mrb627 (Buford, GA)   |   | |
Post# 871000 , Reply# 3   3/7/2016 at 11:18 (2,943 days old) by DADoES (TX, U.S. of A.)   |   | |
This console and control layout is what's on your A612? Assuming so, the designated Delicate cycle is nothing more than a shorter wash period on the Regular Fabrics cycle. The sprays and rinsing sequence are identical regardless of what wash time is chosen. You can select Gentle-Slow for *any* desired wash time and get a "delicate" cycle on either Regular Fabrics (with or without Automatic Presoak) or Permanent Press.
Post# 871020 , Reply# 4   3/7/2016 at 13:01 (2,943 days old) by vacerator (Macomb, Michigan)   |   | |
Do you mean the water level pressure switch? Would it also malfunction on any cycle with a low water level selected? Aren't spray rinses timed? He said they work on the other two cycles. |
Post# 871044 , Reply# 5   3/7/2016 at 14:49 (2,943 days old) by mrb627 (Buford, GA)   |   | |
Post# 871178 , Reply# 7   3/8/2016 at 00:36 (2,942 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 871184 , Reply# 8   3/8/2016 at 01:13 (2,942 days old) by 88gibson (Beverly)   |   | |
Delicate is marked on the Normal fabric side of the dial(6-8 minutes). It only fails to rinse, when delicate, and gentle/slow spin is selected. |
Post# 871207 , Reply# 9   3/8/2016 at 06:43 (2,942 days old) by mrb627 (Buford, GA)   |   | |
Post# 871210 , Reply# 10   3/8/2016 at 07:19 (2,942 days old) by 88gibson (Beverly)   |   | |
Thanks Malcolm! I will give it a try, and let you know. |
Post# 871244 , Reply# 11   3/8/2016 at 08:47 (2,942 days old) by panthera (Rocky Mountains)   |   | |
This topic has come up in the past. I raised it and was given the advice - this was back in Yahoo! group's days - to start a rinse on an empty tub. Spray worked properly, it turned out the belt running the pump was slipping so badly (on a real Maytag, that takes a lot) to drive it. Come to think of it, timer dogs, silly fuse on some later models and slipping belts have been the cause of nearly all our Maytag problems over the decades.
Post# 871263 , Reply# 12   3/8/2016 at 09:49 (2,942 days old) by vacerator (Macomb, Michigan)   |   | |
well what da ya know! Sounds logical at that! |
Post# 871434 , Reply# 15   3/9/2016 at 06:07 (2,941 days old) by mrb627 (Buford, GA)   |   | |
A low/small water level should be long gone by the time the spray should begin. I would continue to look there. Are you sure that both belts are Maytag belts? Or has the drain hose been replaced? Is there a part number on the drain hose? The higher than normal standpipe may also have something to do with it. Malcolm |
Post# 871624 , Reply# 17   3/9/2016 at 21:32 (2,940 days old) by whatsername (Denver, CO)   |   | |
Post# 871669 , Reply# 18   3/10/2016 at 06:01 (2,940 days old) by vacerator (Macomb, Michigan)   |   | |
Yes, a plethora of compounded knowledge, and we are welcome to it all. Like I always say, strength in numbers. |
