Thread Number: 64581
Highlander from vegas |
Post# 872514 , Reply# 1   3/14/2016 at 16:33 (2,957 days old) by bvf ()   |   | |
im getting old and cant do anything right,, |
Post# 872561 , Reply# 2   3/14/2016 at 21:18 (2,957 days old) by washerlover (The Big Island, Hawai’i)   |   | |
I had what appears to be the same model with matching dryer before they were lost in the Valley Fire last Sept. Interestingly, my washer had the same issue -- it would start, then shut itself off. After a few tries, it finally wouldn't turn on at all. Never had a chance to figure it out and am wondering if that's an inherent issues with those machines..?
Post# 872595 , Reply# 3   3/15/2016 at 03:22 (2,956 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
That agitator and lint filter are both very hard to come by and sought after by many. I've been looking for several years for an original Bakelite agitator in good condition with no luck at all. Just about the only place one might expect to find one anymore is in another machine such as your Highlander. Based on the lint filter with the built in fabric softener dispenser I'd guess this is a TA502. A nice machine on it's own but also a great source of some hard to find replacement parts for the higher end models. A very nice find.
Post# 872713 , Reply# 5   3/15/2016 at 18:16 (2,956 days old) by retro-man (- boston,ma)   |   | |
Damn these are all great machines. If you use the search bar of the this and the super forum to learn anything you wanted on this machine. I have seen many comments on those need to be lubed. Jon |
Post# 872793 , Reply# 6   3/16/2016 at 00:04 (2,956 days old) by hippiedoll ( arizona )   |   | |
CONGRATULATIONS!
On such a BEAUTIFUL maytag find! WOWZERS, that turquoise is BEAUTIFUL!! I bet that lint filter screen is alot easier to clean than the plastic ones? Very nice! And yeah, that is a nice agitator! Are the fins solid to the bottom skirt of the agitator? If so, that would be perfect so strapped items of clothing won't get caught under the slots of the fins! CONGRATULATIONS again on the GREAT finds! I look forward to seeing them in action! ;o) |
Post# 873140 , Reply# 10   3/18/2016 at 09:36 (2,953 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
The centrifugal start switch in the motor is probably stuck on start. It should be repairable if the windings aren't smoked too much yet. |
Post# 873313 , Reply# 12   3/19/2016 at 08:26 (2,952 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If the motor turns freely when off but will not start and run when turned on you may have a bad timer or a wire off at the motor or timer. If the timer just energizes the start winding and not the main winding it will behave this way. When looking at the timer look for poped rivets on the timer contacts, this was a big problem on Mallory timers in the early to mid 60s and will cause problems like this. |
