Thread Number: 65043
Whirlpool washer non-agitator type |
Post# 876693   4/12/2016 at 02:57 (2,934 days old) by dandydon (California)   |   | |
I remember a Whirlpool portable model which did not have a agitator but a black paddle in the bottom of the tub. You might almost call the high-efficiency Whirlpool non-agitator model a 'rough' reincarnation.
This Whirlpool model only had one water inlet valve and used a Y-hose connector. The paddle would run for about 20 seconds in one direction, then stop and reverse and operate for another 20 seconds. It created vortex like activity in the tub. The switching to shift the rotation was a mechanical switch driven by a small electric motor possibly a timer motor or two pole shunted type. Thanks |
Post# 876707 , Reply# 1   4/12/2016 at 07:17 (2,934 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 876717 , Reply# 2   4/12/2016 at 08:24 (2,934 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Think is what the OP is referring.
This was a very early washer from WP that had a disk with a sort of fin at bottom of tub which went around, sort of an early version of impeller. Whirlpool called it a "circulator". Pipe: news.google.com/newspapersQUESTI... http://www.ebay.com/itm/Whirlpool-Washer... Someone had one on Ebay last year, but the auction was ended early because item "was no longer available". |
Post# 876757 , Reply# 4   4/12/2016 at 16:20 (2,934 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 877163 , Reply# 5   4/15/2016 at 07:28 (2,931 days old) by Tomturbomatic (Beltsville, MD)   |   | |
laundress, You came up with pictures of the things that said they used a circulator so you get points for that. Good searching! |
Post# 877472 , Reply# 6   4/17/2016 at 18:17 (2,929 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 878141 , Reply# 8   4/21/2016 at 22:41 (2,925 days old) by arrrooohhh (Sydney Australia)   |   | |
This was the second generation machine. |
