Thread Number: 65162
/ Tag: Vintage Dryers
Maytag DE406 |
Post# 877750 , Reply# 1   4/19/2016 at 14:57 (2,927 days old) by Kenmore71 (Minneapolis, MN)   |   | |
That's the hi-limit thermostat on the halo shroud. From the looks of it, you really should replace it.
The cycling thermostat for these dryers is on the blower housing Original part number: 3-3036 Of course this part number is no longer valid, nor is its direct substitute. According to the service manual what you need is a high limit stat with a cut-out temperature of 155 degrees. Because of the way the halo-of-heat dryer works, this hi limit stat has a cut-out temp that is considerably lower than other electric dryers with the element is a separate assembly. I would look for a generic high-limit thermostat with a rating of L150-20F. Or something close to that rating. The L150 indicates the "cut-out" temperature and the 20F indicates that if will cut back in after a temperature drop of 20 degrees Fahrenheit. The original part was technically a L155-30F but I am not finding those on the market, but I did find the L150-20F made by a number of companies out there. CLICK HERE TO GO TO Kenmore71's LINK |
Post# 877771 , Reply# 2   4/19/2016 at 17:32 (2,927 days old) by littlewally ()   |   | |
I found this on ebay. DRYER OR DISHWASHER HIGH LIMIT THERMOSTAT L155-30F PART # 305865 FACTORY SEALED I will purchase this. THANKS!!! |
Post# 877804 , Reply# 3   4/19/2016 at 21:49 (2,927 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes it does look like you should replace the Hi-Limit Thermostat, I would save your time and money and NOT replace the heater element however, unless it has a break in it you can do more harm than good replacing it. MT HOH dryers almost never burned out a heater element unless a metal object falls down on the element and shorts it out.
Do be sure to replace the felt protector that is glued to the front lip of the drum however, this felt ring helps to keep items from falling out of the drum and falling on and shorting out the element and sometimes causing a fire.
MT HOH dryers were easily one of the most dangerous dryers because of the risk of fires from having a heater so close to the clothing. Don't take any chances by running this dryer when you are not around or have gone to sleep. |
Post# 1032161 , Reply# 4   5/8/2019 at 19:51 (1,813 days old) by Maytag85 (Sean A806)   |   | |
This may be a thread from a couple of years ago, but I had something similar happen to my 1974 Maytag DE306, but I was able to fix it, and I had the parts on hand. What happened was it was making a funny burning smell, and I quickly turned the dryer off, and turned off the breaker to the dryer, unplugged it to see what was wrong, and found out that the wire that goes from the heating element to the high limit thermostat actually burnt out on me ( didn’t fully burn out, but practically burnt out on me ). I spent a couple of days fixing and servicing that dryer while I had it completely apart, and when I put it back together and tried it out, it was back to normal. This happened in February, and the DE306 has been in regular use, and seems to work just fine since I repaired it.
