Thread Number: 65333
Unimatic mechanism tear down |
Post# 879425 , Reply# 1   5/3/2016 at 03:11 (2,907 days old) by brucelucenta ()   |   | |
Ask Robert or Greg, they both know how. |
Post# 879444 , Reply# 2   5/3/2016 at 08:04 (2,907 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
What's the problem with the mechanism you're going in to fix? Is it not spinning or spinning-pulsating at the same time? Leaking oil from the top, bottom or both?
The Unimatic shop re-operation manual from the library is great, familiarize yourself with the steps before beginning and then when reassembling, take your time and follow the written instructions and parts breakdown diagrams carefully. |
Post# 879445 , Reply# 3   5/3/2016 at 08:05 (2,907 days old) by swestoyz (Cedar Falls, IA)   |   | |
Is anything wrong with the transmission? Bearing noise during spin, torque spring in tact and it spins up, pulsates fine, fan isn't too noisy? Leaky oil pump? If all of the above are ok I'd suggest changing out the oil and calling it good. The whole "If it ain't broke don't fix it" applies well to these transmissions.
Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 879447 , Reply# 4   5/3/2016 at 08:07 (2,907 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 879481 , Reply# 6   5/3/2016 at 11:00 (2,906 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 879482 , Reply# 7   5/3/2016 at 11:26 (2,906 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 879493 , Reply# 8   5/3/2016 at 14:02 (2,906 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 879564 , Reply# 9   5/4/2016 at 14:33 (2,905 days old) by phmorrow (Knoxville, TN)   |   | |
What could I use for a replacement gasket where the casing comes apart? |
Post# 879566 , Reply# 10   5/4/2016 at 14:38 (2,905 days old) by swestoyz (Cedar Falls, IA)   |   | |
