Thread Number: 65551
HOOVER A3804 AUTO WASHER |
Post# 881567 , Reply# 1   5/20/2016 at 11:19 (2,895 days old) by ServisChris (Southampton, Hampshire UK)   |   | |
Post# 881653 , Reply# 2   5/21/2016 at 11:32 (2,894 days old) by Variatronician (blackpool)   |   | |
Hi mate, thanks, will give that a try. |
Post# 881746 , Reply# 3   5/22/2016 at 13:01 (2,893 days old) by fido ()   |   | |
I would check the pressure vessel for sediment build up. |
Post# 884249 , Reply# 5   6/9/2016 at 16:05 (2,875 days old) by mikeymatic (Manchester UK)   |   | |
Post# 884255 , Reply# 6   6/9/2016 at 16:27 (2,875 days old) by ozzie908 (Lincoln UK)   |   | |
Was this stored or transported on its side at all as that can run moisture into the pressure switch itself and this may take a bit of drying but it can be done!
Before you do anything though go with the tip of cleaning the pressure vessel and also push a screwdriver up the tube an inch or so and after reassemble try the spin again. Austin |
