Thread Number: 65670
/ Tag: Twin-Tub Washers
Hitachi Twin Tub PS 310P |
Post# 882736 , Reply# 1   5/29/2016 at 22:43 (2,885 days old) by barcoboy (Canada)   |   | |
With most twin tubs, after transferring the clothes from the wash tub into the spinner, the operator redirects the drain hose towards the wash tub so that the sudsy water gets pumped back into the wash tub to be reused for the next wash, then after running water over the clothes in the spin tub, the drain hose is returned to the sink and the rinse water is spun out and pumped out the drain hose down the drain. Then, when all the clothes are washed, a knob is turned to pump water from the wash tub instead of the spin tub, allowing the operator to empty the wash tub. Your washer I'm guessing has an internal redirect hose from the spin tub to the wash tub so that you can leave the drain hose in the sink all the time. Turn the dial to "Wash", and the pump returns wash water from the spin tub back to the wash tub; turn the dial to "Rinse", and the pump sends water from the spin tub out the drain hose to the sink; turn the dial to "Drain", and the pump empties the wash tub water out the drain hose into the sink.
Post# 882737 , Reply# 2   5/29/2016 at 22:45 (2,885 days old) by barcoboy (Canada)   |   | |
