Thread Number: 65759
/ Tag: Wringer Washers
Agitator |
Post# 883260   6/2/2016 at 12:05 (2,878 days old) by rene (Toronto, Canada)   |   | |
Hey guys,
I was wondering if I could get some advise on the following: I have Maytag N2LP with turquoise agitator, last couple of time that used the machine the agitator is starting to come off the main post during the wash. Is there a temporary/solution to fix or those this means I have find a replacement agitator. thank you in advance for your advise. Rene |
Post# 883264 , Reply# 1   6/2/2016 at 12:45 (2,878 days old) by vacerator (Macomb, Michigan)   |   | |
I sure miss my old Maytag. I forget if it is an allen bolt, or a screw on the side of the lower agitator which secures it to the shaft. Have you tried tightening it? |
Post# 883277 , Reply# 2   6/2/2016 at 14:36 (2,878 days old) by tinkr (Phoenix Arizona)   |   | |
I have 2 of the the same machines and I believe the stop ring has worn out on yours. It is on the shaft the agitator slides over and keeps the agitator from floating.
There is a seller on e-bay cayuga2 that sells many parts for Maytag wringers. On e-bay search type in Maytag Wringer Washer A4298 Seal for Agitator Shaft Package & Instructions the part I believe you need is labeled stop ring. He may sell them separately. I have one machine the agitator is stuck and one that floats when it stops agitating. I prefer float rather than stuck. hope the link works CLICK HERE TO GO TO tinkr's LINK on eBay |
Post# 883301 , Reply# 4   6/2/2016 at 18:31 (2,878 days old) by goatfarmer (South Bend, home of Champions)   |   | |
