Thread Number: 65862
Need advice with Kenmore 70 series |
Post# 884076   6/8/2016 at 23:29 (2,876 days old) by stan (Napa CA)   |   | |
A friend of mine has an older Kenmore, and it's been leaking a little water. From what I can see it's been leaking from a fairly new pump, and the tub seal. Since I have the tub seal, and the spanner wrench, thought I'd start there. Removed the cabinet etc. Removed tub nut..But can't seem to budge the inner tub loose!
I sprayed WD 40.. Filled with hot water and let set 15 min.. But still no luck. Decided to spray with more WD-40 and wait further advice from here. I've fine this before on my Kenmore? I'm i doing something wrong, or is it rusted on? |
Post# 884082 , Reply# 1   6/9/2016 at 00:49 (2,876 days old) by Stan (Napa CA)   |   | |
Post# 884083 , Reply# 2   6/9/2016 at 00:58 (2,876 days old) by Stan (Napa CA)   |   | |
Was leaking from here? I see no cracks on it anywhere.
Post# 884168 , Reply# 3   6/9/2016 at 11:20 (2,876 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
One thing to watch out for on Whirlpool Direct Drive pumps is the installation. If the old pump had been leaking for some time, the shaft may have started to rust. When the shaft rusts, it can seem to swell. This is especially common if the old pump really fought you when you tried to take it off. If you don't file the shaft back into profile, it will be difficult to reinstall the pump. If you have to force or pound the pump on, the seal in it will fail and it will leak.
I see no obvious sign of failure in your picture (but I could be wrong). I'd say to put it back on the washer and fill it up without the cabinet installed. See where the leak is coming form. Other options may be a worn hose, a faulty water valve, or a bad tub seal. Good luck, Dave |
Post# 884177 , Reply# 4   6/9/2016 at 11:54 (2,876 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 884188 , Reply# 5   6/9/2016 at 12:52 (2,876 days old) by stan (Napa CA)   |   | |
Post# 884213 , Reply# 6   6/9/2016 at 14:58 (2,875 days old) by mrb627 (Buford, GA)   |   | |
Post# 884234 , Reply# 7   6/9/2016 at 15:44 (2,875 days old) by Yogitunes (New Jersey)   |   | |
I just replaced one of those pumps that was leaking from that area as well....as noted, couldn't find it until the cabinet was off, yet looked clean.....
and oddly enough with the new one, it squealed while agitating, so had to take it off and put a few drops of oil in that slot to quiet it down..... sometimes you almost have to jump side to side to get that fitting to break loose, but it will let loose eventually..... keep us posted of your progress..... |
Post# 884355 , Reply# 8   6/10/2016 at 01:43 (2,875 days old) by Stan (Napa CA)   |   | |
Post# 884404 , Reply# 9   6/10/2016 at 09:19 (2,875 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 884407 , Reply# 10   6/10/2016 at 09:39 (2,875 days old) by stan (Napa CA)   |   | |
Post# 884514 , Reply# 11   6/11/2016 at 01:34 (2,874 days old) by Stan (Napa CA)   |   | |
I wasn't heavy enough to break it loose, so I got her husband to do the Temtation walk in it and it finally let go!
Drive block came out with it. Now to clean it up, replace the seal (that from I can seal looks O.K?) replace the leaking pump. Hopefully everything goes back together with any more difficulties |
Post# 884601 , Reply# 12   6/11/2016 at 15:50 (2,873 days old) by mrb627 (Buford, GA)   |   | |
Post# 884645 , Reply# 13   6/12/2016 at 02:04 (2,873 days old) by Stan (Napa CA)   |   | |
Came today, another eBay seller..$9.00 so can't complain if it goes out! And this one..like the last, has no marking on it. No part number, no indication of where it's made. I notice that the part that slides over the drive shaft is a plastic/nylon material, instead of metal?
We'l see. If this one goes out I'll check with FSP. The old tub seal looks O.K and can't see how water got past it, but there is no other place it could be coming from, so tomorrow everything goes back together with a new seal. Watch the SOB will still leak! LOL Here's the new pump
Post# 884668 , Reply# 14   6/12/2016 at 07:21 (2,873 days old) by mrb627 (Buford, GA)   |   | |
Wonder if the machine is failing the neutral drain, causing water to ride against the seal around the splash guard and leak down to the base. The other issue I have run into is un level floor causin tub to lean forward. Fill water collecting or splashing over the splash guard.
Hope it is a simple issue... Malcolm |
Post# 884763 , Reply# 15   6/12/2016 at 18:10 (2,872 days old) by delaneymeegan (Midwest)   |   | |
Post# 885014 , Reply# 17   6/14/2016 at 01:09 (2,871 days old) by Stan (Napa CA)   |   | |
Had partial success..
Since the tub block came off with the tub, I think thats the new problem. I cleaned and replaced the tubs seal on the outer tub.. (Fairly easy) Used a rag and a screwdriver, the garden hose ect to clean the center portion of the inner tub. (Where the floating tub block was) There was no way the block was going to come out.. So I positioned it, (upside down) use a screwdriver and a hammer to drive the block back up into position while still in the tub, or at least I tried to. At that point I already had the outer tub in, pump hooked up, water level tube in, ect. Dropped the inner tub in, and pushed down. It seemed like it went in correctly. Tub nut went on without a problem. Finished reassembly. The good news is that nothing leaks! But when the machine finishes spinning..it makes a load wobbling sound. The only thing I can think of is that I don't have the tub in right? Thought I'd try taking it apart again.. Maybe get the husband to stand in it to make sure it seated good, and try again. Any thoughts? |
Post# 885016 , Reply# 18   6/14/2016 at 01:19 (2,871 days old) by Stan (Napa CA)   |   | |
Post# 885018 , Reply# 19   6/14/2016 at 01:29 (2,871 days old) by Stan (Napa CA)   |   | |
Post# 885117 , Reply# 20   6/14/2016 at 13:06 (2,871 days old) by stan (Napa CA)   |   | |
Post# 885140 , Reply# 21   6/14/2016 at 16:44 (2,870 days old) by mrb627 (Buford, GA)   |   | |
Post# 885145 , Reply# 22   6/14/2016 at 17:12 (2,870 days old) by stan (Napa CA)   |   | |
Post# 885146 , Reply# 23   6/14/2016 at 17:14 (2,870 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
I was going to suggest the same thing. It was a common error in the belt-drive washers to mis-install the drive block on the spin tube. The ears on the spin tube are meant to install into the notches/tabs on the drive block.
If the drive block has had the tabs sheared off, or the ears have gone bad on the spin tube, there won't be a way to mechanically link the spin tube to the drive block and basket, and this creates a nasty groaning sound, especially during breaking. Since the design of the old belt-drive and the direct-drive machines are nearly identical in this specific area, it seems logical that this could happen on direct drives as well. Gordon |
Post# 885217 , Reply# 24   6/14/2016 at 23:32 (2,870 days old) by Stan (Napa CA)   |   | |
Gordon
Yes at present there is a groaning sound! I'm going over tomorrow to take another run at this. I'm anticipating a problem finding the tabs on the drive block and aligning them with the ears on the spin tube because the drive block came out with the tub! Did my best to fish it out through the bottom of the tub, but no luck.. Hopefully there not sheared off! And that I'll be able to see the tabs while still in the tub, and get things lined up. |
Post# 885222 , Reply# 25   6/15/2016 at 00:15 (2,870 days old) by Stan (Napa CA)   |   | |
Getting a length of pipe to go through the tub, and try knocking the tub block out of the bottom.
(Where it should have come from) If I can..then I can at least have a good look at it! and maybe put this back the right way, or ordering a new one.. And by putting the block back on the spin tube independently of the tub (spin basket) |
Post# 885420 , Reply# 26   6/15/2016 at 23:52 (2,869 days old) by Stan (Napa CA)   |   | |
Got a length of pipe knocked out the block that was still in the tub. Then was able to see the tabs!
Cleaned up the block ect and everything went together easy. Washer runs perfect, and quite. Thank guys for your help with this. Working in a dark garage.. Don't know if I'd have noticed the ears and tabs had they not been mentioned. |
