Thread Number: 65920
/ Tag: Wringer Washers
Maytag wringer and a huge wash today |
Post# 884747 , Reply# 1   6/12/2016 at 16:05 (2,867 days old) by ea56 (Cotati, Calif.)   |   | |
Congratulations Gary! The more you use your Maytag Wringer the more you will like it. I've said before on aw.org that to me doing laundry with a wringer washer is a Zen like experience. If we had the room in our townhouse for a laundry tub I would get a wringer washer in a hot second and use it exclusively for our laundry. The clothes come out cleaner in my opinion, even with reusing the wash water. And the fact that you can do a weeks worth of laundry in about a hour is a real plus. Remember to remove the agitator after every wash and rinse out the tub, and leave the wringer rolls apart so they don't flat spot and stick together. I used to occasionally put a light film of vaseline on the agitator post to keep the agitator from getting stuck, (this is what Maytag used to recommend in the owners manual I believe)but if you leave it off between washes that will also prevent it from getting stuck on the post. I hope that you continue enjoy your "new" Maytag.
My routine for washing in a wringer was: 1. Fill the tub to fill line with hottest water possible, add detergent and LBC. Add first load of whites, agitate for 15-20 mins. 2. Run the first load through the wringer into the waiting rinse tub, I just left the agitator on while wringing and was careful while removing items to wring. 3. Add the next load to the washer and while it washes wring out the first load thats in the rinse water. 4. By the time the first load has been wrung out it should be about time to wring out next load that is in the washer. Just keep following this pattern until your wash is done. I used to wash whites first, then sheets, light colors, then towels, and finally darks and levis. Most of the time I could wash 4-5 loads in the same wash water, adding more detergent and hot water for each load as needed, but I usually only used the rinse water twice. Eddie |
Post# 884776 , Reply# 4   6/12/2016 at 19:38 (2,867 days old) by speedqueen (Metro-Detroit)   |   | |
-->Abcomatic, you're making me want to buy another wringer just reminding me how good they wash.
-->Tomturbomatic, we Republicans do not support a polluted environment, but we believe that it is the states' responsibility to regulate the environment, not the Federal government, as per the Tenth Amendment; which states, "The powers not delegated to the United States by the Constitution, nor prohibited by it to the states, are reserved to the states respectively, or to the people." The commerce clause and the "necessary and proper" clause do not provide constitutional legality for regulating pollution. We conservatives believe that some regulation is necessary but what the EPA and Dept. of Energy believe is going far overboard. And Tom, sir, don't take my rebuttal personally, I appreciate that you have an opinion at all in this age of political apathy and lack of knowledge. |
Post# 884823 , Reply# 5   6/13/2016 at 00:11 (2,866 days old) by rp2813 (Sannazay)   |   | |
I've never used a wringer and likely never will. The closest I may ever get is an EASY Spindrier, if I ever find one near me.
It seems to me that the cleaning advantage of wringers is directly related to the ability to use the hottest water one wants, and to agitate for as long as one feels is necessary. Considering this, can it be assumed that an EASY would provide cleaning results equivalent to a wringer? |
Post# 884824 , Reply# 6   6/13/2016 at 00:28 (2,866 days old) by ea56 (Cotati, Calif.)   |   | |
I would completely expect an Easy Spindrier to equal the performance of a wringer for the exact reasons you stated above Ralph. I've owned a Maytag A50 twin tub, which is pretty much like an Easy SD, just a smaller capacity. My experience with the A50 was pretty much the same as wringer. Being able to control the heat of the water and agitation times make all the difference in how clean the clothes will get. When I used either a wringer or the A50 since the first load was whites and the water was the hottest possible I would use a big wooden spoon to fish out the clothes for the wringer (or the spin tub on the A50) on that first load so I wouldn't burn my hands. Also leaving the agitator on helped too since the items would be constantly coming up to the top of the water.
Eddie |
Post# 884828 , Reply# 8   6/13/2016 at 00:58 (2,866 days old) by ea56 (Cotati, Calif.)   |   | |
Gary, I feel like a fool giving you pointers on how to use a wringer! I didn't realize you had so much experience with these kind of machines. I envy you for having a basement with laundry tubs. Do you have a clothesline in the basement to for rainy weather drying? When I was a kid that what my Mom used to due when the weather was bad before we got a dryer.
Eddie |
Post# 884865 , Reply# 9   6/13/2016 at 09:57 (2,866 days old) by abcomatic (Bradford, Illinois)   |   | |
HI Eddie, Yep, I have clothes lines in the basement. I hang the laundry on them in the winter. It helps to humidify the house and they dry overnight. Gary |
Post# 884869 , Reply# 10   6/13/2016 at 10:14 (2,866 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Know persons swear by it and or memory of same, but am a bit weary of such claims as leaving things to wash for ten, twenty, thirty or more minutes in a conventional washing machine.
Looking at some of the central beaters these machines had back in the day you'd have a tub full of tattered rags if you allowed things to be agitated for extended periods. Even on normal speed have read that machines like the Maytag wringers aren't for "Walmart" clothes. Hems of new sheets and such have reportedly been torn apart. Reading owner's manuals and operating guides for Maytag, Whirlpool, Speed Queen, ABC, etc... most all gave recommended wash periods that ranged from a few minutes to perhaps fifteen at the most. The latter was for very sturdy (and dirty) things that could withstand being beaten about that long. As for wringer washers (and or twin tubs) getting laundry cleaner than automatics still stand by my original observation; it is the lifting laundry out of mucky water rather than allowing it to strain through it that contributes to a cleaner wash. |
Post# 884876 , Reply# 11   6/13/2016 at 10:34 (2,866 days old) by ea56 (Cotati, Calif.)   |   | |
Well Launderess I haven't washed in a wringer since 1973 and at that time wasn't washing Walmart clothes. But I never recall anything falling apart or being torn to shreds by a 15-20 min wash time. That's the way my Mom, Grandma and Aunts did it and I'm pretty sure if items were being torn up in the washer we would have known about it. The tub was never packed tightly on these machine, you only add clothes up to the point that they will move freely in the wash water. Most of the time I only washed the whites about 15 mins. successive loads were probably about 10 mins or so. All I know is everything always came out very clean and the whole process for 4 loads usually took about an hr. from start to finish. And yes the clothes were being lifted out of the dirty water to put them through the wringer, but the dirty water was pushed through the fabric while going through the wringer so in a sense it still srtained through the fabric. But the copious amount of clear rinse water in the waiting tub took care of that.
Eddie |
Post# 885091 , Reply# 15   6/14/2016 at 10:43 (2,865 days old) by speedqueen (Metro-Detroit)   |   | |
That would require that we throw out all country sovereignty as well, to quote Earnestine the operator, "we are omnipotent," would become the world governments' motto."
Common sense regulations are acceptable, but as we know first hand the Dept. of Energy's latest water requirements for washers and latest energy regulations on dishwashers are ridiculous. This is a very big problem because congress is supposed to make laws but they have delegated their power to the executive branch, something that strict constructionists like myself believe is unconstitutional. My proposition for the regulations is to transfer them to the states using categorical grants. |
Post# 885128 , Reply# 16   6/14/2016 at 15:43 (2,865 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Can only go by what one has read on various other websites and from reading various online copies of conventional washer owner's manuals.
Have a few hand cranked wringers in my stash, and that gets old very fast. One or two bed sheets and am "done". *LOL* Tried a blanket once (the Miele refused to balance the thing properly to spin without banging itself to death), and won't be doing that again anytime soon. Have toyed off and one with getting a wringer washer or an Easy spin drier. Mainly for getting through piles of bed linen faster than the hour and plus either the Miele or AEG take to do just one load. Laundry Alternative now sells a "mega" spin dryer they claim has a 22lb capacity. Could just do loads of linens in wash tub and bung the lot into that huge extractor. www.amazon.com/Laundry-Al... Have seen a few Bock centrifuge extractors on offer, but they are just too big and bulky. |
Post# 885151 , Reply# 17   6/14/2016 at 18:23 (2,865 days old) by ea56 (Cotati, Calif.)   |   | |
I found a Maytag Wringer manual online and you are correct that Maytag did suggest 5-10 mins. for whites and cottons, but also said you could wash for longer time if needed.
My family probably didn't read the "distructions", but my experience was about 15 mins, maybe 20 for whites depending upon soil level. But successive loads were closer to 5-10 mins. I just washed as long as seemed necessary, never any damage to fabric. The spin drier from Amazon looks like a good idea. But better yet, if you still have your Hoover Twin tub and it is working why not use it? This would do away with having to wash the linens by hand. I think the wash tub on the Hoover is larger than the Maytag A50, which I used to have. I washed 1 kingsize sheet and pillow case at a time or 1 blanket. Of course comforters unless a twin size would be out of the question, I did wash double chennile bedspreads though, the spinner was really at max capacity doing this, but did a fine job of extraction anyway. I like twin tubs for smaller homes and apartments, they are essentially like using a wringer, but with faster and better extraction, and really easy to store as I'm sure you know. Eddie |
Post# 885179 , Reply# 18   6/14/2016 at 21:00 (2,865 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 885186 , Reply# 19   6/14/2016 at 21:27 (2,864 days old) by ea56 (Cotati, Calif.)   |   | |
your Hoover Twintub won't work out for you. I've never used a Hoover twintub, only the Maytag version. Since the Maytag A50 has 2 impellers that reverse direction about every 30 sec. the clothing moves very well and does't tangle. I'm not familar with how the Hoover single impeller works, does it also reverse direction? Anyway, that spin drier you're looking at on Amazon would probably be a great solution for you and it certainly is reasonably priced.
Eddie |
Post# 885303 , Reply# 20   6/15/2016 at 11:10 (2,864 days old) by countryguy (Astorville, ON, Canada)   |   | |
Post# 885349 , Reply# 21   6/15/2016 at 17:05 (2,864 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Those old marketing materials from Hotpoint got it right; Hoover TT's with their rear mounted impellers aren't the best for laundry. Things often tangle into a mass then do not move freely in water, thus you get poor cleaning.
Long as the load is made up of small and or mixed items, and or the bed sheets in question are twin or perhaps full sized; things perhaps can work. But am here to tell you queen or king heavy muslin or linen sheets are a royal pain. |
Post# 886953 , Reply# 22   6/25/2016 at 20:59 (2,854 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
It becomes clear why they became the gold standard.
Maytag was the first and seems only conventional washer to go with one soft wringer roller. This coupled with their self adjusting ballon wringer system meant safety: even if one's hand were drawn into far as lower arm, less harm would come it seems than with hand operated and other mangles. Maytag was one of the first and perhaps only wringer washers with sediment traps. Many later automatics incorporated that feature but not wringer washers. From top to bottom Maytag seemed right to the end interested in creating a quality product. |
Post# 890102 , Reply# 25   7/20/2016 at 07:37 (2,829 days old) by beekeyknee (Columbia, MO)   |   | |
If you want a Maytag automatic, install a toggle switch on the back of the machine, splice into the timer moter leads, hook them up to the switch and you can extend any part of a cycle you like. The machine becomes a semi-automatic at that point, when you use the switch, but it will do what you want. Just don't fall asleep when the switch is flipped or you could end up with an extremely long spray spin or clothes washed to death. This can be done on any automatic with mechanical timer and probably with digital one if you're sharp enough.
