Thread Number: 65951
Maytag A208 Timer |
Post# 885126 , Reply# 1   6/14/2016 at 14:55 (2,843 days old) by brucelucenta ()   |   | |
If you take off the front of the washer there should be one glued to the outside of the tub. |
Post# 885133 , Reply# 2   6/14/2016 at 16:04 (2,843 days old) by rp2813 (Sannazay)   |   | |
Maybe this picture will help. You can try using the "super searchalator" at top right of the index page. Type in "maytag a208 timer" to pull up archived threads that may provide useful information.
Also, I've provided a link to a service manual download that may help.
CLICK HERE TO GO TO rp2813's LINK |
Post# 885195 , Reply# 3   6/14/2016 at 22:00 (2,843 days old) by Rookie1 (Indiana)   |   | |
THANKS!! I was totally stumped |
Post# 885219 , Reply# 4   6/14/2016 at 23:41 (2,843 days old) by rp2813 (Sannazay)   |   | |
Post# 885260 , Reply# 5   6/15/2016 at 07:03 (2,842 days old) by Rookie1 (Indiana)   |   | |
I'll keep you posted(no pun intended). I should be able to get over there Thursday evening, is the washer front just held on by clips and lifts off or are there some hidden screws I need to look for? |
Post# 885275 , Reply# 6   6/15/2016 at 08:13 (2,842 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 885319 , Reply# 7   6/15/2016 at 14:28 (2,842 days old) by rp2813 (Sannazay)   |   | |
Post# 885387 , Reply# 8   6/15/2016 at 19:32 (2,842 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 885392 , Reply# 9   6/15/2016 at 20:08 (2,842 days old) by rp2813 (Sannazay)   |   | |
Post# 886113 , Reply# 11   6/20/2016 at 11:34 (2,837 days old) by Rookie1 (Indiana)   |   | |
Disconnected the wires from my brothers install, reconnected the timer using the numbers on the wires(still perfectly readable) and Bingo, back in business. Thanks to all for your help!! |
Post# 886425 , Reply# 13   6/22/2016 at 12:26 (2,835 days old) by rp2813 (Sannazay)   |   | |
Considering that the timer and the water temperature selectors are two separate systems, it seems odd that the warm or cold wash/rinse settings would have any effect on the timer's function.
If you're getting warm and cold water into the tub by manually advancing the timer, the cold valve solenoid must be OK.
This is beyond my scope and will require advice from the experts. |
Post# 886429 , Reply# 14   6/22/2016 at 13:18 (2,835 days old) by Jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 886432 , Reply# 15   6/22/2016 at 13:32 (2,835 days old) by rp2813 (Sannazay)   |   | |
Post# 886488 , Reply# 16   6/22/2016 at 19:33 (2,835 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 886578 , Reply# 17   6/23/2016 at 10:14 (2,834 days old) by Rookie1 (Indiana)   |   | |
Thanks guys, I'm going over there today to see if it will fill on cold. A new water inlet valve is only 22 bucks. Where is it located? I'm thinking it's behind the hose input? |
Post# 886620 , Reply# 18   6/23/2016 at 18:22 (2,834 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 886749 , Reply# 19   6/24/2016 at 11:42 (2,833 days old) by Rookie1 (Indiana)   |   | |
It does not fill on cold, so I think the inlet valve is probably the right direction. I'll get it changed after it comes in and keep my fingers crossed. |
Post# 886773 , Reply# 20   6/24/2016 at 14:20 (2,833 days old) by goatfarmer (South Bend, home of Champions)   |   | |
