Thread Number: 65986
/ Tag: Twin-Tub Washers
Hoovermatic 3310E |
Post# 885468   6/16/2016 at 06:27 (2,864 days old) by skeggy56 (skegness, Lincolnshire, England)   |   | |
Hi guy's just a quick question about my washer, When i fill the washing drum the water is also filling the spinner, is this normal or is some sort of valve stuck, it washes fine and spin's fine it's just that the spinner fills up with water when not spinning, any advice welcome. Thank's Kev. |
Post# 885470 , Reply# 1   6/16/2016 at 07:21 (2,864 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Kev
As you are probably aware the spin pump is used to empty the wash tub so it sounds like the pump valve is either stuck or the "flapper" inside is worn and is letting the water seep through from the wash tub into the spinner. The valve assembly clips off the pump and is fairly easily removed so you can see what is happening as the valve is rotated. I may have a spare myself, otherwise Matthew (Keymatic3203) may be able to help. Al |
Post# 885543 , Reply# 2   6/16/2016 at 14:40 (2,864 days old) by skeggy56 (skegness, Lincolnshire, England)   |   | |
Vacbear58, You were spot on, one of the seal's on the valve had come off not allowing the unit to effect a seal, I cleaned up the unit replaced the sealing "bung" and heypresto one working 3310 again, Happy day's. Thank's for your reply it's much appreciated. All the best Kev. |
Post# 885637 , Reply# 4   6/17/2016 at 01:57 (2,863 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
