Thread Number: 66371
/ Tag: Vintage Dishwashers
KDS-18 - looking for info on the door seal |
Post# 889861 , Reply# 2   7/18/2016 at 12:08 (2,830 days old) by frogkid11 (Richmond, Va)   |   | |
Just checking to see if anyone has any experience or advice with this seal. TIA ! |
Post# 889945 , Reply# 3   7/19/2016 at 01:23 (2,830 days old) by beekeyknee (Columbia, MO)   |   | |
Does this look like what your problem might be? (Link)
As far as the leak around the bi-metals that open the detergent dispenser doors, the bi-metals don't leak. The door pins or hinges that are spring loaded from the back side can leak, as well as the gasket that surrounds the whole dispenser. Try tightening up the screws surrounding the dispenser and then try some Zoom-Spout oil or Tri-flow oil on the inside where the springs loaded doors pivot and a little dab on the inside pivot area too. Then work the dispenser doors, closing and opening them by tripping the doors manually by moving the bi-metals with a small pointed object, like a toothpick or something similar. Do this when the machine is not running, of course. Then run it with powdered detergent (not gel or packs/tabs) and watch it. Use a paper towel or old bath towel to wipe up any excess oil and/or water that might run down on the back side of the dispenser. Be careful if it's running. 120V is directed through those bi-metals during the dispense segment of the timer as voltage is directed through the bi-metal from the motor to make it bend. If you ground it out you could be shocked and never short the two leads to the bi-metal together. The voltage travels through the bi-metal and is the load. If you short it by touching the leads together, touching the leads with you finger or a wet rag you will have an unpleasant experience. This might stop the leak. If it doesn't you might have to disassemble the dispenser doors by removing the cotter pin. This will cause the dispenser doors to fly out into the machine's tank. You might want to hold you hand over the doors so they don't fly into the tank. Sometimes old plastic breaks easily. I've never done this personally but I've been told there are tiny "O" rings on the shafts of those doors or in the body of the dispenser. Somewhere in there. They may have deteriorated beyond usefulness. If you decide to remove the whole dispenser, be very careful. The rubber seal under the dispenser can be torn easily and there is usually rust under there that you will have to clean off the door and gasket. This can be a risky move and that gasket is really hard to find. You can get the oils at Ace Hardware and most likely the "O" rings too. This is the best advise I can give you. I hope it helps. PB Blaster is a good penetrating spray for old screws and gaskets but it stinks to high heaven, so be prepared if you use it. You can download the service manual for a KitchenAid KS 18 series off of Automatic Ephemera. That might help you for other things in the future. CLICK HERE TO GO TO beekeyknee's LINK This post was last edited 07/19/2016 at 02:50 |
