Thread Number: 66493
Washer Drains and Fills |
Post# 891155 , Reply# 1   7/26/2016 at 19:13 (2,828 days old) by chetlaham (United States)   |   | |
Post# 891163 , Reply# 2   7/26/2016 at 19:55 (2,828 days old) by pbutler5 (COLUMBUS)   |   | |
here's some pictures, what do you mean up to the control panel? |
Post# 891218 , Reply# 5   7/27/2016 at 06:50 (2,827 days old) by brucelucenta ()   |   | |
Poor kid, he just didn't know! You have to keep the drain hose up to about the height of the back of the machine for it to operate properly. Otherwise the water just runs out. |
Post# 891248 , Reply# 6   7/27/2016 at 11:58 (2,827 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Also, it looks like your drain hose is too small in diameter. The pump out time with a smaller hose like this will be longer than normal, and may not allow allow enough full speed spin time.
That hose you're using should be able to fit INSIDE the correct size drain hose normally used on a Maytag like this one. |
