Thread Number: 66729
Maytag A712 - Calling all experts! Help w/ troubleshooting |
Post# 893937 , Reply# 2   8/14/2016 at 19:35 (2,803 days old) by sarat (USA)   |   | |
Thank you so much for taking the time to answer. You're right, it sat for about six months in someone's garage. Can you tell me where I can locate the pump / pump pulley? Thank you again. |
Post# 893959 , Reply# 3   8/14/2016 at 22:46 (2,803 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Those Maytag pumps are in the right side front with motor in left side front. It might be best to pull the front panel off with the 2 screws and clips and you can see just what your problem is. One of our members posted a video, I know its on you tube of the Maytag 906 going thru a complete cycle and the inner workings. Everything below the console is the same thru the mid 80's other than the capacity.
Post# 893964 , Reply# 4   8/15/2016 at 00:56 (2,803 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
When you say you can't get the water to drain, is the washer attempting a spin cycle? These machines have reversing motors, so during agitation the motor turns one way, then during spin it turns the other way. The duration of the spin cycle is controlled by the timer, so if the motor isn't reversing the washer would appear to do nothing for a spell as the timer continued to advance until the spin time was used up. Then since the water hadn't drained out the fill level selector switch contacts would still be closed and the timer would continue on with the rinse cycle agitation.
The plastic Maytag pumps are pretty bullet proof so it's hard to imagine one seizing up unless some foreign object got inside and jammed it. Also noteworthy is that pump is in constant motion during agitation and spin. If it truly is seized up you would likely smell and hear something as the belt is dragged across the stationary pulley - that is unless the belt is missing altogether. I suppose that's also worth looking into. This post was last edited 08/15/2016 at 02:22 |
Post# 894043 , Reply# 5   8/15/2016 at 15:24 (2,802 days old) by mrb627 (Buford, GA)   |   | |
Post# 894049 , Reply# 7   8/15/2016 at 16:22 (2,802 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 894072 , Reply# 8   8/15/2016 at 22:16 (2,802 days old) by rp2813 (Sannazay)   |   | |
Post# 894101 , Reply# 9   8/16/2016 at 04:27 (2,802 days old) by sarat (USA)   |   | |
Agree. Probably won't take 15-25 minutes... It's a perk of being female. I know I'm getting hosed but not in a position to do anything about it. |
Post# 894242 , Reply# 11   8/16/2016 at 21:58 (2,801 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 894244 , Reply# 12   8/16/2016 at 22:16 (2,801 days old) by repair-man (Pittsburgh PA)   |   | |
We would be pretty close to those prices. Our service call is a little less ($60) but I think the pump does sell for closer to $70. So about $150 total repair. $270 seems unreasonable in my opinion. |
Post# 894354 , Reply# 13   8/17/2016 at 13:54 (2,801 days old) by d-jones (Western Pennsylvania (Pittsburgh Area))   |   | |
If your agitator has no set screw on the side of the barrel then you remove it by pulling it straight up. There is a rubber stop ring mounted below the splines on the steel shaft that the agitator sits on and that is generally all that holds it in place. The stop ring has a slightly larger diameter than the bottom of the agitator so you'll need to pull up firmly to get it to compress enough to let the agitator slip past. Unfortunately, depending on how old the stop ring is it may have hardened up a bit with age making this potentially very difficult.
As to the little hole in the agitators skirt that you mentioned, by design the agitator will trap an air pocket underneath it as the tub fills with water. That little hole simply allows some of the air to bleed out so that the air pocket is no larger than needed.
Post# 894413 , Reply# 15   8/17/2016 at 21:31 (2,800 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi the washers with a screw to hold the agitator in place do not use a rubber O ring.
Maytag went to the screw to hold the agitator in place because the older machines that only used a rubber O ring the agitators would occasionally fly off the post during the spin cycle and cause injury or other washer damage. |
