Thread Number: 66909
POD 8/28/2016 |
Post# 896145 , Reply# 6   8/29/2016 at 10:07 (2,790 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
CURRENTLY AVAILABLE SOLVENTS: Perchloroethylene: Or PCE is the most common solvent and has been in use since the 1940s. PCE is becoming less popular due to its ground contamination problems and potential health effects. Hydrocarbon solvents: This is less aggressive than PCE and require a longer cleaning cycle. Although combustible, they do not present a high risk of fire or explosion when used properly. Hydrocarbon also contains volatile organic compounds (VOCs) that contribute to smog. Dibutoxymethane: (trade name SolvonK4) Is a bipolar solvent that removes both water and oil based stains. SolvonK4 is considered to be one of the best replacement solvents for PCE as cleaning performance is very similar. Liquid silicone: (decamethylcyclopentasiloxane or D5) is gentler on garments than PCE and does not cause color loss. It is licensed by GreenEarth Cleaning. Though more environmentally friendly, its more expensive and degrades within days in the environment to silicon dioxide, water and CO2. Produces nontoxic, nonhazardous waste. Brominated solvents n-Propyl bromide: (Fabrisolv, DrySolv). It cleans faster, but it can damage some synthetic beads and sequins if not used correctly. Health-wise, there are reported risks associated with nPB such as numbness of nerves. Supercritical CO2: Machinery is expensive - up to $90,000 more than a perc machine, making affordability difficult for small businesses. CO2-cleaned clothing does not off-gas volatile compounds, so environmental impact is very low. Glycol ethers: (dipropylene glycol tertiary-butyl ether) (Rynex, Solvair, Caled GenX and Impress) is proposed an environmentally friendly competitor with PCE with processing advantaged. Lower cycle times, with reduced detergent provides better cleaning than longstanding leader PCE. Modified Alcohol: is an environmentally friendly alternative for PCE and HCS with processing advantages. Better cleaning than PCE, less greying than with HCS, easier to dry than HCS, low odor. PREVIOUS SOLVENTS: Carbon tetrachloride Highly toxic. Trichloroethane Overly aggressive and harsh. Stoddard solvent Very flammable and explosive, 100 °F/38 °C flash point. CFC-113 Freon Ozone destroying CFC. This post was last edited 08/29/2016 at 10:33 |
Post# 896147 , Reply# 7   8/29/2016 at 10:12 (2,790 days old) by A440 ()   |   | |
Thanks Kevin! So many Chemical choices.....
