Thread Number: 66967
maytag a700 |
Post# 896726   9/1/2016 at 08:53 (2,786 days old) by cradersd (san diego)   |   | |
my old maytag hums but will not agitate or spin. what should i check first? |
Post# 896728 , Reply# 1   9/1/2016 at 09:19 (2,786 days old) by Yogitunes (New Jersey)   |   | |
Post# 896781 , Reply# 2   9/1/2016 at 16:17 (2,786 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 896863 , Reply# 3   9/2/2016 at 09:08 (2,785 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 897013 , Reply# 4   9/3/2016 at 15:09 (2,784 days old) by cradersd (san diego)   |   | |
belts are good. at the start of spin cycle machine makes its usual clunk and about a quarter turn then stops and hums. so if not belts - ?? |
Post# 897034 , Reply# 5   9/3/2016 at 18:32 (2,784 days old) by Yogitunes (New Jersey)   |   | |
Post# 897066 , Reply# 6   9/3/2016 at 23:15 (2,784 days old) by cradersd (san diego)   |   | |
yes, i can spin the pulleys by hand. so that means the transmission is locked up? |
Post# 897107 , Reply# 7   9/4/2016 at 07:52 (2,783 days old) by Yogitunes (New Jersey)   |   | |
Post# 897146 , Reply# 8   9/4/2016 at 12:39 (2,783 days old) by cradersd (san diego)   |   | |
yes, motor runs w/o belts on. |
Post# 897161 , Reply# 9   9/4/2016 at 14:56 (2,783 days old) by cradersd (san diego)   |   | |
i fixed the brake last year with a new gear. could the brake be locking it up? |
Post# 897164 , Reply# 10   9/4/2016 at 15:04 (2,783 days old) by Yogitunes (New Jersey)   |   | |
could, but you said it spins and releases fine....
just wondering if its the motor, works OK alone, but under a load, theres not enough strength.... seems odd for everything to work not attached, yet assembled together, and something is stopping it... if it was just a spin issue, I would almost say theres a sock stuck between the tubs....but since it wont agitate either... this one is a puzzler |
Post# 897302 , Reply# 12   9/5/2016 at 15:42 (2,782 days old) by Yogitunes (New Jersey)   |   | |
Post# 897306 , Reply# 13   9/5/2016 at 16:20 (2,782 days old) by goatfarmer (South Bend, home of Champions)   |   | |
