Thread Number: 67071
Maytag a108 stops after fill cycle, will advance if manually turned |
Post# 897796 , Reply# 1   9/8/2016 at 17:17 (2,758 days old) by Yogitunes (New Jersey)   |   | |
now this is an odd one.....
timer not advancing, that would be a timer issue on its own, to be exact the little motor that turn the timer would be the culprit.... by any chance, is the timer motor pugged in exactly where it needs to be....because, if that wont turn, neither will the timer..... had seen ones too, the little gears of that tiny motor were broken, and as such, the timer would not advance....you may have to pull that motor off and see if it is turning..... |
Post# 897804 , Reply# 2   9/8/2016 at 18:45 (2,758 days old) by Bigterkc (Kansas City)   |   | |
Post# 897812 , Reply# 3   9/8/2016 at 19:55 (2,758 days old) by super32 (Blackstone Massachusetts)   |   | |
If i read this correctly. Timer has been replaced. Wiseman859 said "wont advance after fill cycle" I could be wrong but that tells me it fills then just stops? I have seen a pressure switch or two, fill and stop at the proper water lever. But never close the full circuit to the timer to say "run". Strangely the two times were both on Maytags. If this is the case, i would think the rinse cycle would be a problem but there is no mention of the rinse.
Just my thinking....... |
Post# 897849 , Reply# 4   9/9/2016 at 06:01 (2,758 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Does agitation start when the water is full/turns off? The timer motor 'should' run any time the main motor does. Additionally, the timer motor runs between agitate and drain/spin while the main motor is off for the reversing contacts to operate.
Thus the timer motor and main motor are both connected to the N.O. contact of the fill switch during fill and agitate. Within the timer there is a provision (contact set) for separating TM and MM during drain/spin. So that TM can run while motor is pausing. Also during this time, fill switch will open so there is a contact set for MM power to bypass it.
All that makes more sense if you're following a wiring diagram, which would greatly speed up zooming in on the problem. So would an AC voltmeter, used very cautiously while the power is connected. You can also use an ohmmeter with machine unplugged. That is safer if you are not accustomed to working on hazardous voltage. |
