Thread Number: 67085
POD 9-9-16 MAYAG AD IS A LIE |
Post# 897889 , Reply# 2   9/9/2016 at 10:13 (2,757 days old) by kd12 (Arkansas)   |   | |
I see the dryer here has a magnetic latch and not the old handle latch that would eventually work loose and scrape the front of the door. Does anyone know what year the old handle latch went away? |
Post# 897890 , Reply# 3   9/9/2016 at 10:17 (2,757 days old) by Yogitunes (New Jersey)   |   | |
I believe all Maytags did a full one minute timer increment for the spray rinse....not 30 seconds...
but all in all, back then, whether you got a BOL or TOL, the base unit was a solid built dependable machine......not dubbed down versions with ply tubs, cheap plastic, lower quality metals......lower price=lower standards..... even this 106 was available with a suds saver option!... of course too, they make no mention that the lint filter functions best with higher water levels... |
Post# 897909 , Reply# 4   9/9/2016 at 11:24 (2,757 days old) by bajaespuma (Connecticut)   |   | |
Or maybe Maytag did what GE did a zillion times which was to publish a product brochure ahead of the new line's production and then made some changes that didn't appear until the next year. I prefer those early proto-power fin agitators with the attached fins that shot the lint water out of the underside; they seemed to provide more vigorous washing action and I maintain that the power fins snagged a lot of clothing. |
Post# 897921 , Reply# 5   9/9/2016 at 12:44 (2,757 days old) by mrb627 (Buford, GA)   |   | |
Post# 897960 , Reply# 6   9/9/2016 at 16:36 (2,757 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Well, the suspension is quite different, the polypump is different, the cabinet is slightly different, and the control panel is very different. The basic design of the guts was a carry-over, as was the slower stroke transmission and old agitator design. I believe the inner tub was a carry-over from the old design and was updated when the Power Fin agitator was introduced.
Dave |
Post# 897975 , Reply# 8   9/9/2016 at 18:17 (2,757 days old) by Gyrafoam (Wytheville, VA)   |   | |
I have a 106 and I can't tell the difference between the performance of that machine and my A-300 Highlander which is much older. Both do a terrific job of washing. No complaints. |
Post# 897981 , Reply# 9   9/9/2016 at 19:01 (2,757 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
My 511 has peformed pretty much flawlessly. I had my guy come today because it stopped pumping, 2nd repair ever. He looked at it and said nothing wrong with the pump, but after 35 years the pump moved left. He pulled and secured it right to where it should be and it pumps like new. He said dont ever get rid of this washer because you wont ever get another washer as good as this.
This post was last edited 09/09/2016 at 19:45 |
Post# 898043 , Reply# 11   9/9/2016 at 23:50 (2,757 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
My mom had the even more newer A-106 washer, similar but slightly different--though it did have the all-white plastic timer dial... The entire agitator was blue...
Simple machine, and even with the choice of water levels and variety of wash temperatures, still being something that washes right, after you simply just set and forget, every time!
The dryer she'd bought a mere couple months later abandoned the Halo-Of-Heat design, so it had a larger door w/ the lint filter right in the threshold... And it was a model, or two, up as well...
-- Dave |
Post# 898123 , Reply# 13   9/10/2016 at 14:20 (2,756 days old) by Yogitunes (New Jersey)   |   | |
Post# 898129 , Reply# 14   9/10/2016 at 14:44 (2,756 days old) by Gyrafoam (Wytheville, VA)   |   | |
There was a difference in agitation speed when the Power-Fin was introduced (1966 as I recall), however, I think it is the same tranny. The Power-Fin having a slightly faster occilation. I always did favor the long, slow stroke. Just 'sayin. |
Post# 898136 , Reply# 15   9/10/2016 at 15:21 (2,756 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 898365 , Reply# 16   9/12/2016 at 09:21 (2,754 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Between the AM / AMP series and the Orbital, there were 3 similar, but different Maytag transmissions. Working backwards they are:
Large capacity tub (short transmission). This transmission's guts are the same as the taller regular capacity transmission used with the later Power Fin equipped washers. I believe the agitation speed on regular speed is 63 OPM. Regular Capacity tub with Power Fin agitator. I believe the agitation speed on regular is 63 OPM. Regular capacity tub, pre-Power Fin. This is the transmission used on the early A106 & A206 washers (before the Power Fine), as well as Highlanders, A700, A702, and others. I believe the agitation speed of this transmission is 54 OPM. The case is the same as the later regular capacity tub model, but the gears inside have different tooth-counts. Dave This post was last edited 09/12/2016 at 10:21 |
Post# 898367 , Reply# 17   9/12/2016 at 09:42 (2,754 days old) by swestoyz (Cedar Falls, IA)   |   | |
The change to the 63 OPM standard capacity transmission in the A106 and A206 occurred in November of 1967, which correlates to the change to the Powerfin agitator. Prior to this, the Powerfin agitator was only used in the Large Capacity machines.
Even if the transmission and agitator were carry over from the pre-New Generation or '06' machines, almost everything else was different with the new generation (with the exception of the lid/motor/poly pump and a few other items). I'd much rather have an 06 std or large capacity machine than the previous generations, with the suspension changes being the most important improvement.
There is a reason why we are still finding 1966 through mid 70's Maytags, still in use. They apparently got something right.
Ben CLICK HERE TO GO TO swestoyz's LINK |
