Thread Number: 67136
/ Tag: Vintage Dishwashers
Hobart KDC 57a dishwasher dumping water all over the floor Help! |
Post# 898697 , Reply# 4   9/14/2016 at 07:00 (2,780 days old) by DADoES (TX, U.S. of A.)   |   | |
The pressure switch is not intended to control the normal fill level. Fills are timed. The pressure switch only comes into play to stop the fill if an overfill condition occurs so something is causing overfilling if the pressure switch is involved in stopping the water flow. One suspect, as Combo52 advised, is a worn/bad drain impeller that isn't fully draining the tub, which leaves enough water that the next timed fill causes an overfill. Or a clog somewhere in the drain path that's obstructing the flow. Or a worn flow-control washer in the inlet valve. |
