Thread Number: 67686
POR15 Durability |
Post# 904057   10/23/2016 at 22:56 (2,733 days old) by DADoES (TX, U.S. of A.)   |   | |
Has anyone who has treated an outer tub, centerpost, etc. with POR15 done a follow-up disassembly to check how it holds up over time? I did a break-down on a direct-drive unit on which I treated the centerpost and base pedestal five years ago. I found that the POR flaked, loosened, and peels off the centerpost very easily. Same on the base to a degree, and there's some rusting coming through on it in a few areas. Based on what I see I'm doubtful that it'd hold up for the long-term on an outer tub, rusted areas on a porcelain basket, etc. Maybe my technique is bad? |
Post# 904077 , Reply# 2   10/24/2016 at 06:56 (2,733 days old) by Gyrafoam (Wytheville, VA)   |   | |
I used it extensively on a '55 Unimatic restoration (from the dreaded Aberdeen Farm) I did about twelve years ago and no problems to report. In fact, the whole INNER tub is coated with it. Outer tub of '67 Rollermatic is ok. '66 Hotpoint ok. |
Post# 904106 , Reply# 3   10/24/2016 at 11:33 (2,733 days old) by turquoisedude (.)   |   | |
Post# 904107 , Reply# 4   10/24/2016 at 11:44 (2,733 days old) by swestoyz (Cedar Falls, IA)   |   | |
POR-15 is great. I've had great success using it on KM/WP belt-drive center posts and sealing up rusty tub outlets on Maytag outer tubs. The instructions do indicate that cleaning and prepping the surface is a must, but this stuff LOVES to adhere to rust. I have see instances where it will flake off porcelain surfaces, but that won't stop me from using it in the future.
Ben |
Post# 904109 , Reply# 5   10/24/2016 at 11:49 (2,733 days old) by kb0nes (Burnsville, MN)   |   | |
